CJ-
Well I replaced both my phasers Wednesday, one had a broken pin that held part of the spring up while the other phaser looked ok, replaced them both and everything went well, she started up and ran smoother and was quiet/no phaser tap.
And Friday on my way home from work, the CEL lit up and when I got off the freeway I heard tapping and while I haven't diagnosed the CEL/check engine light... I strongly suspect a phaser failed,
My question to you guys is weather not I sheared the locking pin... When I was torquing the drivers side phaser down, the Tone Wheel turned when I was about halfway through the final 90 turn on the Phasers mounting bolt, does that mean I sheared the locking pin?
