Heated Seat Replacement Element?????
100mileperhour
Brooklyn, MI
The heated seats on my 13 Mustang don't work. Discovered the reason, while replacing the seat cover and found both the upper and lower elements with broken wires. Looking for a source or a "retrofit" where I can solder the wire to use the exiting connector. The factory replacement is no longer available. Hoping someone with some knowledge, could point me in the right direction for a source.
I did attempt to solder it all back together, but when tested, seems to have a short.
Thank you!
have you searched the site, I know there are threads on this topic, quick look turned up these:
slonison
Clifton, nj
Homie.
If it's the wires that go into the connector that are just broken, use a crimp butt shrink connector that is 18 or stronger gauge.
Otherwise,
Here are the connectors you are looking for:
Connector Brand: YAZAKI
Connector Series: 1.5x0.8 Series
Manufacturer Search Results: YES/YESC Kaizen Connector 1.5X0.8 Series details | YAZAKI Connectors Catalog
Connector Pins/Terminals: 2
Connector Female Part#: 7283-6444-60
Manufacturer: YES/YESC Kaizen Connector 1.5X0.8 2P Female│YAZAKI Connectors Catalog
Mouser: 7283644460 Yazaki | Mouser
Digikey:
Connector Male Part#: 7282-6444-60
Manufacturer: YES/YESC Kaizen Connector 1.5X0.8 2P Male│YAZAKI Connectors Catalog
Mouser: 7282644460 Yazaki | Mouser
Digikey:
>C335/C3310
Connector Female Part#: 7283-6443-40
Mouser: 7283644340 Yazaki | Mouser
Digikey:
Connector Male Part#: 7282-6443-40
Mouser: 7282644340 Yazaki | Mouser
Digikey:
These should work:
Female:
Terminal
YES/YESC Kaizen Connector 1.5X0.8│YAZAKI Connectors Catalog
7116410002 Yazaki | Mouser
Male:
Pins
1.5(060) Connector Terminal Male│YAZAKI Connectors Catalog
7114410002 Yazaki | Mouser
When in doubt, come to my connector list
Source: I did this last winter, so I know all about everything related to this.
100mileperhour
Brooklyn, MI
Thank you for your replies!
No, the wires are broken on the mat itself. I attempted to solder it all back together, but it's weak and I still have a short. So looking for a suitable replacement element. Something that I can solder the stock pigtail connector to.
My electrical knowledge is very limited, but does the group have any thoughts about simply using this kit and just swapping the connectors with the factory ones from the OEM element?
