What was it rubbing against? Just curious if what it was rubbing against needs to be replaced, also.
Mine is doing the same thing. It didn't do it until I put my lowering springs on! The design of that little hump where it hits is so that even smacking it with a 6 # sledge hammer barely dings it..the thing is STRONG!
Which DS is that?
You've got a pretty good drop on your car. Thinking any 4" DS is going to cause the same problems. Maybe you can go with a 3.5".
who makes a 3" DS im scared of the same thing happening to me
Honestly I don't think any of them will work without some modifications to the tunnel....Not with a hammer....
Before you go beating the living crap out of the underside of your ride, I think this is the key to the problem...you have more travel because of the shortened stops...you could get some new ones, and try that, or you could get some springs with a higher spring rate... just myI also cut an inch off my bump stop to get a little better ride so that could be the reason I'm having more problems then some of you all?!? (a little more travel)
That's too easy...I like the idea of a bigger hammer better.
You could get a smaller diameter (3.5") chromoly driveshaft... Would be a little heavier, but still quite a bit ligher than stock with the all the other benifits of a 1pc - I have adjustable springs on my car so it has been up and down according to various tire diameters and I don't see how I would not get rub with such a large drop...Meee Too!!!
I would hate to replace the stops, buy Another driveshaft and still have the problem. ..... ...
