Pics of my rubbing driveshaft....Is this bad?? :)
TheBOSS
I ride the short bus!
Missouri
I took it off Saturday and went back with my stock shaft for now. I'm getting ready to call the company and see what they'll do about this....
1Fast05Turbo
Flying Low
Valrico, FL
From the pics can't tell how deep the groves are but I would think those groves will compromise the driveshaft strenght and maybe the balance.
TheBOSS
Missouri
What was it rubbing against? Just curious if what it was rubbing against needs to be replaced, also.
Just the top of the driveshaft tunnel.....a seam where the floor and the tunnel are spot welded. This is the area they told me needed "Massaged" for it to clear........:naughty:.......I beat on it with a sledge a little but it didn't budge. I'm not sure what is up but I'm thinking my car is just too low for a 1 piece? With stereo equipment I would say its 2.5" - 2 3/4" in the rear....
ulev1st
Mustang Addict!
Memphrica, Tn
Mine is doing the same thing. It didn't do it until I put my lowering springs on! The design of that little hump where it hits is so that even smacking it with a 6 # sledge hammer barely dings it..the thing is STRONG!
TheBOSS
Missouri
Amen brotha!! I hit it pretty hard and it won't budge. I'm glad to hear I'm not the only one with this problem(not really but..), I was starting to think I was crazy...
TheBOSS
Missouri
Which DS is that?
Coast driveline shaft from Stangsuspension dot com....
I called them earlier and they said "No problem" send it back! I have to pay shipping but thats better than eating $600!!
scramblr
New Braunfels, Texas
You've got a pretty good drop on your car. Thinking any 4" DS is going to cause the same problems. Maybe you can go with a 3.5".
TheBOSS
Missouri
Honestly I don't think any of them will work without some modifications to the tunnel....Not with a hammer.... :)
TheBOSS
Missouri
My car has BMR lowering springs, 2" in rear, and I have maybe 100lbs. of stereo/wood in the trunk so its a little lower. I also cut an inch off my bump stop to get a little better ride so that could be the reason I'm having more problems then some of you all?!? (a little more travel)
All I know is that once you have it and you go back to the stock shaft, it kinda suxs!
scramblr
who makes a 3" DS im scared of the same thing happening to me
Denny's is the only one I know of...but let's not even go there.:naughty:
Spyder - 4" GT Aluminum - 16.5 lbs
Coast - 4" GT Aluminum - 17 lbS
Power House Automotive - GT 4" Aluminum - PHA-DS05 - 19 Lbs
BMR Fabrication - GT 3.7 Carbon fiber - DS005 - 20.7 Lbs
Denny's Drive Shaft - GT 3" Steel - FM200567NR - 23Lbs
Lethal Performance - GT 3.5" Aluminum - DSS-FDSH4 -
My daddy always used to say that if it didn't work the first time...get a bigger hammer.:clap:
KIMMER
Admin
Spyder is 4" to 3" tapered shaft. Get ahold of ron, but pretty sure it would clear.
scramblr
It's 3" in the front right under the shifter. I don't think it will help in the middle of the tunnel. I think a bigger hammer is in order. :rock:
MrClean
Marc; but I go by MrClean
Friendswood, TX
Before you go beating the living crap out of the underside of your ride, I think this is the key to the problem...you have more travel because of the shortened stops...you could get some new ones, and try that, or you could get some springs with a higher spring rate... just my :2cents:
scramblr
That's too easy...I like the idea of a bigger hammer better. :samuri:
cekim
Large Member
Earth
Meee Too!!!:kinky:
I would hate to replace the stops, buy Another driveshaft and still have the problem. ..... ...
You could get a smaller diameter (3.5") chromoly driveshaft... Would be a little heavier, but still quite a bit ligher than stock with the all the other benifits of a 1pc - I have adjustable springs on my car so it has been up and down according to various tire diameters and I don't see how I would not get rub with such a large drop...
I got a rubber skidmark on my DS when dropped about 1-3/4. During burnouts it would hit a glob of "undercoat" that accumulated at the rear of the tunnel.
Bingo
Because street car
Phila, PA
Is this a unique problem? There has to be more people running 1-piece driveshafts along with lowering springs.
How did you figure it was rubbing? Was it making noise?
