Scott
Planning a Ford Racing “Aluminator” Build with associated mods over the winter. Let me know what you think, what am I missing? Car is not a DD and is used in fair weather mostly at show-n-shines and cruises. I drive like a citizen on the street, but want to make reasonable power for “bragging rights”.
For completeness I have included below the “Winter Build List” all of the current modifications to my car.
Winter Build List (format - Manufacture, Description, Part # and Current status):
• FRPP 4.6 Liter Aluminator Short Block 9.8:1 Compression Ratio, M-6009A463V – Inventory
• FRPP 4.6 Liter 3V Performance Intake Manifold, M-9424-463V – Inventory
• FRPP 4.6 Liter 3V 62mm Billet Throttle Body, M-9926-3V – Installed
• FRPP High Flow Fuel Injectors, Flow Rate 60 lbs/hr @ 39.15 PSL, M-9593-LU60 - Inventory
• FRPP CNC Ported 3V Cylinder Heads , M-6050-N3VPA (LH) and M-6049-N3VPA (RH) – Wish List
• FRPP Performance Head Gaskets, M-6067-3V46 - Inventory
• FRPP High Performance Oil Filter, M-6731-FL820 – Inventory
• FRPP 3V Header Gaskets, M-9448-A463V - Inventory
• ARP 4.6L 3-Valve Head Studs, 256-4202 – Wish List
• Moroso Performance Parts Ford Modular 7qt Capacity, 6 ½” Deep Sump Oil Pan, 20548 - Inventory
• TSS 3V/GT500 Oil Pump Assembly w/ Billet Gears and O-Ringed Pressure Discharge Mounting Surface – On Order
• Ford OEM Oil Pan Gasket, 3L3Z-6720-AA - Inventory
• Vortech 6 Rib Supercharger Pulley (2.87”), 2A036-287 – On Order
• Comp Cams 4.6L Modular 3V Ford 2005 & Newer Cam Phaser Limiter Kit, 5449 – Wish List
• Comp Cams Beehive™ Valve Springs: Top 1.013" O.D., .650" I.D.; Bottom 1.101" O.D., .738" I.D., 26125-24 – Wish List
• Comp Cams XFI™ SPR Ford 4.6L/5.4L Modular 3V Cams (Springs and Phaser Modifications Required), 127550 – Wish List
• Comp Cams 7 Degree Titanium Retainers: .959” Spring Diameter, 702-24 – Wish List
• Ford OEM Cam Phaser Bolts, 2 @ 3L3Z-6279-DA - Inventory
• Ford OEM VCT Housing Gaskets - 3L3Z-6C285-AA Right Hand and 3L3Z-6C286-EA Left Hand - Inventory
• Ford OEM 2 Valve Steel Bodied Tensioners, F6AZ-6L266-DA Right Hand and F6AZ-6L266-CA Left Hand - Inventory
• Ford OEM Timing Cover Gaskets, 4R3Z-6020-BE, 4R3Z-6020-DB, 4R3Z-6020-EB - Inventory
• ATI, Super Damper Serpentine Series, 918039 – On Order
• ARP Harmonic Damper Bolt, 156-2501 – Inventory
• Ford OEM Crankshaft Key, FLAZ-6B316-AA – Inventory
• Ford OEM Front Oil Seal, XW4Z-6700-AA - Inventory
• PRW SFI 3V 8-Bolt Flexplate - PRW Platinum Series SFI-Rated Steel Flexplate, 1828111 – Inventory
• ARP Flexplate Bolts (8), M10 x 1.00 (UHL .800), 254-2901 – Inventory
• UPR Billet 3 Bolt Tensioner and Custom Billet 76mm Tensioner Pulley - UPR 3030-02 and Carmen Goudey S197 76mm Pulley - Installed
• ARH Mustang 3V 2005-2010 Stainless Steel Headers1 ¾” Primaries w/Catted X-Pipe, MST0634WC - Installed
• Mangnaflow Ford Mustang GT, Shelby GT500 3 inch Cat Back Exhaust, 16674 - Installed
• Stage 8 Stage 8 Locking Header Bolt System 8mm, 1.25x22mm, 8906M – Inventory
• Circle D Specialties Multi Disk Performance Torque Converter, ?? – Wish List
• Performance Automatic 5R55 Deep Aluminum Pan and Filler Tube Set, PA27455KT – Installed
• Performance Automatic Hardened Transmission Input Shaft for Ford 5R55S, PA27406 – Inventory
• TCI Auto StreetFighter Ratchet Automatic Shifter, 619570 – Installed
• TCI Auto Hi Performance Transmission Servo Kit, 3rd Gear Servo Kit, 576005 – On Order
• TCI Auto Hi Performance Transmission Servo Kits, 4th Gear Servo Kit, 576006 – On Order
• Canton Racing Products Automatic Transmission Expansion Tank, 45-000 – Inventory
• B&M Racing and Performance Products Hi-Tek Transmission Cooling System, 70297 - Inventory
• Hypertech Power Stat 160 Degree Thermostat Mustang GT (05-09), HYP1011 – Inventory
• BeCool Direct Fit Cross Flow Radiator, 60205 – Wish List
• Meziere Enterprises Electric Water Pump Relay Kit, WIK346 – Wish List
• Meziere Enterprises Electric Water, WP346S - Wish List
• Royal Purple, Purple Ice Radiator Coolant Additive, 01600 - Inventory
• Royal Purple Engine Break-In Oil, 11487 – Inventory
ALL current modifications to my car:
Engine:
• Vortech V-3 Si-Trim HO Polished Supercharger with Charge Cooler
• Canton Racing Products Aluminum Coolant Expansion Tank
• DiabloSport MAFia
• Ford Racing Performance Parts High Performance Oil Filter FL-820
• JLT Performance Oil Separator Catch Can
• FRPP 3V Spark Plugs 12 MM (M-12405-3V12MM)
• Moroso Performance Parts Aluminium Intercooler Coolant Tank
• Royal Purple 5W20 Synthetic Oil
• Russell Performance -12AN Stainless Steel Hose and Aluminum Fittings for Intercooler Coolant Lines
• Shelby Performance Parts Oil Pressure Gauge Adapter
• Steeda Billet Charge-Motion Delete Plates
• Taylor Performance Parts Trunk Mounted Aluminium Battery Box
• UPR Billet 3 Bolt Belt Tensioner and 76mm Carman Goudey Pulley
Fuel Delivery:
• Ford Racing Performance Parts 62mm GT Billet Throttle Body
• Ford Racing Performance Parts GT 500 Dual Fuel Pump System
• Ford Racing Performance Parts 39 lbs/hr Fuel Injectors
• Fore Precision Billet Fuel Rails
• Fore Precision Mustang GT Fuel Rail Install Kit
• Russell Performance Stainless Steel Fuel Hose Kit
• Gasoline - Sunoco/Petro Canada 94 Octane
Exhaust:
• American Racing Headers Stainless Steel Long Tube Headers 1 ¾” Primaries
• American Racing Headers X-Pipe Crossover with Cats
• Magnaflow Cat-Back 3” Stainless Steel Exhaust System with Magnapacks
• Stack Racing Stainless Steel Exhaust Hangers
Under Hood Styling:
• California Pony Car Radiator Extension Covers
• Cervini’s Auto Design Hood Struts
• Ford Racing Performance Parts Coated 3-Valve Cam Covers
• Kirban Performance Chrome Plated Hood Latch
• Moroso Brake Reservoir Cover
• Polished Stainless Steel Fender Bolts
• Steeda Polished Billet Fuse Box Cover
• Steeda Polished Billet A/C Check Valve Cover
• Stack Racing Chrome Cap Dress Up Kit
• UPR Polished Billet Battery Tray
• UPR Polished Vapour Vent Cap Cover
• UPR Polished Billet Cowl Pin Cap Covers
• UPR Polished Billet Throttle Body Actuator Cover
• UPR Polished Billet Coil On Plug (COP) Covers
• UPR Polished Billet Oil Dipstick Handle
Tuning Software:
• SCT X3 Tuner - Tuned by DaSilva Racing
Driveline:
• Axle Exchange 4” One-piece Aluminum Drive Shaft w/Pinion Flange
• BMR Suspensions Front Drive Shaft Loop
• Ford Racing Performance Parts 4.10 : 1 Ring & Pinion
• Ford Racing Performance Parts Ring and Pinion Installation Kit (B)
• Ford Racing Performance Parts 8.8” Aluminum Differential Girdle/Cover with Stainless Steel Fasteners
• Ford Racing Performance Parts Friction Modifier
• Ford Rear Axle Vent Hose Assembly
• Lube Locker 8.8” Differential Gasket
• Performance Automatic 5R55 Deep Aluminum Pan, Stainless Steel Fasteners and Filler Tube Set with Dipstick
• Royal Purple Max-Gear SAE 75W140 Gear Oil
• TA Performance 8.8” Bearing Cap Stud Kit
• TCI Auto StreetFighter Ratchet Shifter
Front Suspension / Bracing:
• BMR Suspensions Tubular K-Member
• BMR Suspensions Tubular A-Arms
• BMR Suspensions A-Arms Support Brace
• Ford Racing Performance Parts Mustang GT Jounce Bumpers
• Ford Racing Performance Parts GT Strut Tower Brace
• Ford Racing Performance Parts SVT Strut Rubber Insulators
• Maximum Motorsport Caster/Camber Plates
• Maximum Motorsport Strut Mount Hardware Kit, Strut to Spindle
• Shelby Performance Parts Adjustable Front Sway Bar End Links
• Steeda Sport Springs
• Steeda Adjustable Front Sway Bar
• Steeda Light Weight Radiator Support
• Tokico D-Spec Adjustable Struts
Rear Suspension / Bracing:
• BMR Suspensions Xtreme Anti Roll Bar
• Bump Stop Frame Brackets Removed
• Jounce Bumper Relocation Plates
• Steeda Adjustable Panhard Bar
• Steeda Heavy Duty Panhard Bar Brace
• Steeda Adjustable Upper Control Arm
• Steeda Billet Lower Control Arms
• Sway Bar Axle Housing Mounts Trimmed for 15”x10” Rim Clearance
• Tokico D-Spec Adjustable Shocks
• Tokico D-Spec Shock Adjuster Extensions
• UPR Lower Control Arms Relocation Brackets
Interior:
• AeroForce Interceptor Scan Gauge
• Amustangrocksleather.com ¾ Length Leather E-Brake Arm Cover
• Amustangrocksleather.com Padded Leather Arm Rest Cover
• Auto Meter Nexus Series Gauges: Fuel Pressure, Wideband Air/Fuel Ratio, Vacuum/Boost,
• Auto Meter Nexus 8 Channel Sensor and Remote
• Ford Racing Performance Parts - Ford Racing Logo Floor Mats
• Ford Racing Performance Parts GT500 Leather Wrapped Steering Wheel
• Glove Box Trunk Release Push Button
• Pioneer Electronics AV Receiver w/iPod Control, DVD Playback & Bluetooth AVH-P3200BT
• Pioneer Electronics Car Deck Remote CD-R55
• Pioneer Electronics Front Speakers TS-D6802R
• Roush Performance Vent Gauge Pod
• Speed of Sound Dove Gray “A” Pillar Triple Gauge Pod
• Speed of Sound Center Dash Triple Gauge Pod
• Steeda Billet Pedal Covers
• Steeda Billet Dead Pedal
• UPR Polished Billet Front Speaker Rings
• UPR Polished Billet Mirror Control Knob & Bezel
• UPR Polished Billet Door Pins
• UPR Polished Billet E-Brake Handle
• UPR Polished Billet Power Plug
• UPR Polished Billet Cup Holder
• UPR Polished Billet Ultra Light Door Handles
• UPR Polished Billet Designer Door Pin Bezels
• UPR Polished Xtreme Billet Window Switch Plates
• UPR Polished Billet Map Light Buttons
• UPR Polished Billet Seat Recliner Lever
• UPR Polished Billet Seat Release Lever
• UPR Polished Billet Power Lumbar Seat Switch Button
• UPR Polished Billet Power Seat Button Covers
• UPR Polished Billet Headlight Knob Cover
• UPR Polished Billet AC Knob Covers
• UPR Polished Billet Large Oval Clothes Hangers
• UPR Polished Billet Lock Switch Covers
Exterior:
• Agent 47 Brake Cooling Scoops
• American Muscle Mirror Covers, Paint Code: JV
• Anzo USA Euro w/Amber Reflector Park Lights
• Cervinis Ram Air Type IV Hood with Billet Inserts
• Covercraft Technalon Car Cover – for car storage
• Ford Racing Performance Parts SVT GT500 Spoiler
• Silver Horse Racing California Special Honeycomb Lower Grille
• Silver Horse Racing Honeycomb Deck Lid Panel
• Smoked Rear Tail Lights
• Stack Racing 8” Shorty Antenna
• Stack Racing Black Tail Light Trim Bezels
• Street Scene Center Fog Light Honeycomb Grille
• UPR Polished Billet Aluminum Gas Cap Cover
• WebElectric Sequential Turn Signals
Brakes, Tires and Wheels
Front:
• Nitto NT-555 - 255/45 R18 103W (Street)
• SVT GT 500 Mustang - 5-Lug, 4.5” Bolt Circle, 7.125” Backspacing, 45mm Offset 18” X 9.5” (Street)
• Ford Racing Performance Parts Open End Wheel Nuts for SVT Wheels (Street)
• M&H Racemaster Front Runner Radial 185/55/17’s (Strip)
• Race Star Industries Drag Wheel 5-Lug, 2.5” backspacing, 17” x 4.5” (Strip)
• McGard Drag Racing Lug Nuts (For Race Star Wheels with ARP Studs) (Strip)
• Agent 47 Brake Cooling Kit
• Baer Pro+ 6P, Six Piston Calipers, 2 Piece 14” Slotted and Drilled Rotors & Stainless Steel Lines
• Ford Racing Performance Parts Front Hubs with ARP Long Wheel Studs
• Russell Performance Speed Bleeders
Rear:
• Nitto NT-555 - 285/40 R18 101W (Street)
• SVT GT 500 Mustang - 5-lug, 4.5” Bolt Circle, 7.125” Backspacing, 45mm Offset 18” X 9.5” (Street)
• Mickey Thompson ET Street Radial 325/50/15’s (Strip)
• Race Star Industries Drag Wheel, 5-Lug, 7.5” Backspacing, 15” x 10.0” (Strip)
• ARP Long Wheel Studs
• Baer Decela Slotted and Drilled Rotors
• Dupli-Color Red Painted Calipers
• Stop Tech Stainless Steel Brake Lines
Engine:
• DiabloSport MAFia
Fuel Delivery:
Exhaust:
Under Hood Styling:
Tuning Software:
Driveline:
Interior:
Exterior:
Front:
Rear:
