Goose
2007 GT/CS
A couple of weeks ago I went to the track and while I was staged with my 2 step, I blew the driver side header gasket, causing the car to back fire a few times. Hearing this, I didn't race the car down the track, and I ended up just driving it home afterwards (about 5 miles).
I then took the car to a local shop to have the header gasket replaced. After the gasket was replaced, I could now hear a knocking sound coming from the driver side valve train (sounds as if I had a slight exhaust leak). The knocking sound increases and decreases with the rpms, and it never goes away, but the cars performance has not gotten worse.
After reading around this forum and the web, I began to suspect (or at least hope) that the problem was a collapsed lash adjuster. The car was also about a quart low on oil, so I am thinking that I might have starved a lash adjuster and caused it to fail.
Today I took a stethoscope to the cam cover and the valve train sounded normal except over the #5 cylinder. Here I could hear a much louder sound. So I took off the cam covers, and now I want to check to see if any of the lash adjusters are bad. So my question to those who know is, what is the proper method for verifying if I have a bad lash adjuster? Is it just a matter of having the base of the lobe on the follower whose lash adjuster I am checking? If so, am I then checking for excessive wiggle of the follower?
Thanks for any input which anyone might have, and sorry that its a bit of a long read, but I wanted to provide as much info as I could about how the problem happened.
