PMAS HPX and HPX-E Mafs
The HPX
The HPX will support the following horsepower
3" housing 640 WHP
3.5" housing 870 WHP
80mm or stock 05GT airbox 700 WHP
85mm housing 800 WHP
95mm housing 1000 WHP
100mm housing 1100 WHP
Updated sensor curve has been engineered to maintain perfect idle resolution even when used on vehicles making under 300HP.
This sensor can be used in any housing from 2" to over 5". It can also be used for blow-thru or draw-through configurations.
Limited lifetime warranty.
This is the last mass airflow sensor you will ever buy.
*Requires 05+ Ford maf connector
*Requires computer tuning
*Can be used on any 0-5V maf system with computer tuning
*Transfer function generating software tool available for FREE download
http://www.pmas-maf.com/resources/PMASHPXtool.xls
The HPX-E (Extended Range, 30% more range than standard HPX)
Extended range HPX
Will never peg.
The HPX-E will support the following horsepower
3" housing 840 WHP
3.5" housing 1140 WHP
80mm or stock 05GT airbox 920 WHP
85mm housing 1050 WHP
95mm housing 1300 WHP
100mm housing 1450 WHP
Bobby
turbo gt about to go fast
here is the link for the maf transfer function program for the hpx maf. you must multiply the flow values by 1.3 if using the hpx-e. if you are using just the hps then you dont have to. the first is the new style maf and the second link is the old one the 2011 up maf used the gt500 maf transfer function. also here is a 05 maf pin out http://www.pmas-maf.com/resources/05...0and%20HPX.jpg
http://www.pmas-maf.com/resources/PMASHPXTOOL2014_2.xls
http://www.pmas-maf.com/resources/tools/HPXtool.XLS
HPX-F
PMAS HPX-F MAF SENSOR
For FORD vehicles utilizing frequency based maf sensors. (2010+)
Will never peg. Sensor will support over 700HP when installed in a 3" housing.
Sensor has two times the range of the stock sensor.
Designed to have the factory GT500 transfer function when installed in a 3" tube for ease of tuning.
*Requires 2010+ Ford maf connector
*Can be used on any frequency based maf system with computer tuning
