Powder Coating Services!!!!!!
johnnyv8
South Jersey
I'd be interested in the pricing for powder coating my throttle body in Ford Blue...
Shoot me a price and timing to do the job...
No hurry because here in Chicago, the winter is setting in fast so the car will not see daylight for about 4 months...
Dave
We have a throttle body we'll be doing for my car (test piece). After that, my core will be available discofan!
johnnyv8
South Jersey
Dave,
They look great! Thank you again for all the good words. Like disco was asking, I think the throttle body is going look nice and compliment the valve covers very nicely if you looking to powder coat other things :)
Fallenauthority
La Plata, MD
Just an FYI, the throttlebodies will come out fine. Just make sure it gets reassembled properly. It will set some codes if not put back just right. The bearings last through the cure no problem.
johnnyv8
South Jersey
Thanks for the heads up Fallen. Your stuff looks good, you know I had to check out the comp:naughty1:
JoshK
Modder AKA Fuel
Nebraska
+1 on the throttle bodies coming out just fine. Fallen did mine and it is back on the car and working great. I was the guinea pig for this and am glad I did it.
johnnyv8
South Jersey
Well, we have a extra TB will be powder coating black, so my car going be the guinea pig, LOL. How do you like your on3 kit Fuel? I just installed mine, still need to tune it!
Motivology
Arizona
Looks like I found my new powdercoater! I have an 07 Harley Davidson F150 truck... hm... what is there to powdercoat? LOL! :D
johnnyv8
South Jersey
Our main thing has been valve covers, and were moving into throttle body's. However pretty much any metal that can fit in a conventional oven will work.
I google your truck and it appears your valve covers our cursed like the s197 valve cover...Ugly LOL
Motivology
Arizona
Ha I know, I gotta get some dough to make the engine bay nicer but first thing's first.
Davenow
Austin TX
Hey semi related question...
Are there any black powdercoatings that can hold up to flames and 500+ deg heat? I was thinking of powdercoating my grill plates (as in my gas grill) since they always get surface rust over the winter.
Fallenauthority
La Plata, MD
There are coatings that can last in that environment, problem is you have to find one thats safe for contact with food
johnnyv8
South Jersey
Im talking about a gas grill outside. With burner flames an inch away, and sometimes coming up through. I can get that grill up to 500 with all the burners on and lid closed.
They have quite a few different high temp powders that would easily handle those temps. However neither of them are FDA rated to be used with food. There is one FDA approved powder that I found but does not specify the temp that it can handle.
dysan
Dis-Member
Williamstown, N.J.
I would think the only reliable coating for something like that is going to be porcelain. I wouldn't trust powder to hold up to that since the direct heat is going to be probably over 1000 degrees.
