power steering hose seal thingy....
one eyed willy
Pizzle fo shizzle
Lakeland FL
anyone have any info on this, the little plastic seal that i found in there was pretty chewed up.....
08nastygt
Ravenna oh
I had to replace mine as it leaked also. That's for the high pressure side right? I bought the whole new line for 50 since my turbo pipe burnt through the wrap n started to melt it.
george06
Take the hose/line to a Hydraulic shop, they will use a micro-meter to measure it and will give you what you need. Cost $2.00
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Teflon seal. One-time use, obviously.
Mine was buggered up like that, and would leak of course. I just put some sealant on the threads and it stopped leaking.
o2sys
NY/NJ
found them! advance auto parts store......in the help section $3
Is this the correct teflon seal for the pressure hose to pump?
What about the o-ring from the pressure hose to the rack?
My high pressure line hose got a pin hole sized leak and need replacing.
