scramblr
So for us ignorant of gears, what are we looking at and what's wrong with it? Guessing the "teeth" marks in the center is one of the outcomes of the problem?
Question for y'all with the spydershaft: if you get up to ~105 and left off the gas and shift to neutral, do you get a reverberation as the speedo passes through 100-95-90? I seem to. It doesn't seem to do it under load, or at least I can't hear/feel it over the engine/tranny NVH, and when I say under load, I mean both ways...it doesn's seem to do it decelerating in gear (as much) as when it is in neutral....any similar experiences?
Can y'all try this and report back?
Should I start a new thread?
Just messing with you Man. I replied in the other thread.No, I think you should post the same question in all the Spyder threads...Oh wait, you just did. LOL...Just messing with you Man. I replied in the other thread.
I'm not schooled in gears either, and I was waiting for Dave to come in but he's obviously tied up for the time being. Basically it's gear walk that caused those teeth marks.So for us ignorant of gears, what are we looking at and what's wrong with it? Guessing the "teeth" marks in the center is one of the outcomes of the problem?
Dave isn't sure what the main cause of the walk was, or if it was a combination of things. He said the install kit I supplied him with may have had some defective parts (which may be true). He also noticed that the preload (tuning torque on the flange ) on the pinion bearings was less than 5in/lbs and said it should be in the 20in/lb range. At first he thought the cause of that could be me tightening the pinion nut down too far, or the hard tapping I did to free the flange may have contributed, but when he reinstalled the flange/new pinion nut/bearings he too had to tap the flange off, and also had to torque the nut down far more than I ever could just to get the preload in the correct 20in/lb range so I don't think those could have caused it.
Here's what Dave did after seeing the damage. He looked over the parts and felt the carrier was fine even with the scoring, and that the teeth on pinion were not damaged enough thus were reusable. The bearings had some pitting/scoring so he changed those out. Before putting it back together he did the following:
Pinion bearing preload with new bearings: Ford spec: 16-29 in/lbs mine were set at 20 in/lbs. Ring gear backlash: Ford spec .008 to .015 in mine set at .011. Filled her up with Royal Purple.
He took the car for a spin up to 60, and all seemed fine. The problem is that the previous vibration started @ 65 and got ridiculous at 80 and above. So on my way home I was able to run it up to speed...the car felt fine for about 15 minutes but then the dreaded vibration returned.
At this point I'm thinking a whole new gear set is in order. The set I bought on eBay (new-but you never know) may have been defective, so this time it will be directly from FRPP. I've troubled Dave enough with this, so this time I will have a differential shop do the next install.
To be continued!
That's a great idea....they can get it from FRPP...even if it costs you $25-50 more..it sorta buys u insurance.Dave sounds like a hell of a guy, but the next shop may not be. May want to consider buying the gears through the shop, that way if anything is wrong, they're still responsible. Otherwise they may blame the parts which means you're forking over parts and labor all over again. Just a thought...
Zackly... I've been singing that song for a couple years. I've had two sets of gears installed, and I provided absolutely nothing to the installer either time.May want to consider buying the gears through the shop, that way if anything is wrong, they're still responsible. Otherwise they may blame the parts which means you're forking over parts and labor all over again. Just a thought...
Ok I am finally here...
That really sounds like something in the differential. Problem is that the stock shafts were designed to hide the vibration problem Ford couldn't fix(or didn't want to spend the $ to resolve) so it could have been there since the car was new and you just never knew about it.Question for y'all with the spydershaft: if you get up to ~105 and left off the gas and shift to neutral, do you get a reverberation as the speedo passes through 100-95-90? I seem to. It doesn't seem to do it under load, or at least I can't hear/feel it over the engine/tranny NVH, and when I say under load, I mean both ways...it doesn's seem to do it decelerating in gear (as much) as when it is in neutral....any similar experiences?
Dave is a great guy, and he has treated me better than any other shop EVER has, which is why I don't want to put him through anymore of this.Dave sounds like a hell of a guy, but the next shop may not be. May want to consider buying the gears through the shop, that way if anything is wrong, they're still responsible. Otherwise they may blame the parts which means you're forking over parts and labor all over again. Just a thought...
Dave, I appreciate you showing up on here. It's funny you mention the housing because I recently read that housing flex can cause gear walk. Like I said when we first met, the vibration started between 2-500 miles after buying the car new.
Edit: Seeing Ron's comment about the carrier may just be the answer to my problem. What is your recommendation to replace the carrier, Ron.
Welcome Dave!PS thanks to all the gave me a welcome to the board.
You rock, Dave! I wish more people in this business would emulate your practices.Don't worry about bothering me with this problem. This is what I do for a living. I actually really appreciate you as a customer. Your really understanding about all this and it makes working with you and enjoyable experiance. Like I said I am not only here to make a living I am here to make you guys happy also.
I would love to have the pinion angle checked. I'm not sure if it can be adjusted without me having an adjustable upper control arm. I think we may be able to do it by putting the car on the lift, measure the PA on both the tranny and DS flange. If it's off, then we detach the DS from the pinion flange, and jack up the differential to the desired angle, then reattach. I'm not positive, but I think this would work.As for the carrier being the problem (which I am not saying it is or isnt) that still wouldnt correct case run out if the housing is out of wack. But if the carrier is the problem you may actually gain in this one. But it could get expensive. You have 31 spline axle stock in these years (all years prior had 28 spline) If you remember I showed you that Eaton locker diff sitting on my self at the shop. I love that unit I have put so much hp through those diffs I am actually surprised it took it. I try to use them in all my cars. I say you gain because the stock track lock diff from ford are not really the best. Now the down fall to the Eaton locker is when turning you can kinda hear it working back there. Its normal, so that diff probably isnt for you since your not shooting for the moon in the hp catagory. But there are other way better than stock diffs out there that would work good for you.
I keep reading the pinion angle issue. Maybe with your rear of the car lower and the front isnt and with the new DS maybe the pinion angle is off. I would check that before anything else IMO.
Thanks again for your awesome attitude and service, Dave. As for the next shop, I'm not sure where I will take the car. I still would like for some others to chime in with their advice before I try another gear install.Again like I said your not bothering me with this. But I am not perfect, I might be missing something stupid. Maybe a second opinion wont hurt on this issue cause something weird might be going on...
I did see on another thread here where Ron (Spyder Shaft CEO) mentioned crush sleeve issues causing similar problems. I believe you put a new crush sleeve in on Monday, so we can discount that as a cause.
