problem with bmr safety loop
08gt4u
has anybody had a problem with the safety loop hitting the x pipe.on the lift there is a 1 inch clearance between each other but while driving and hitting a speed bump or going on a driveway they hit each other.
69Mach1-409
South Jersey
I know we had to 'trim' the edges of the BMR to clear the 'off-road' ProChamber. We just 45'd them and it was fine. ..but mine was actually hitting while on the lift.
Question: do you have the midpipe hangers on yours? Only reason I ask, is because that would explain why the midpipe is moving so much and why it wouldn't be hitting while on the lift.
Liberty911
FLA
I had the same problem. I have LTs so I was able to loosen the connections and make adjustments at the header and mid pipe location to get the necessary clearance.
08gt4u
yes i do have the midpipe hangers.what parts are you guys actually trimming?the only way i can see this clear it with no problems will be to cut about a 1/2 inch from the bottom of it and reweld it again.we play with it a little and 1 inch was the best clearence i got.at one point it was resting direct on the x pipe.
69Mach1-409
South Jersey
I trimmed the ends of the angled bar that mounts to the trans mount.
08gt4u
thanks for the pictures but mines is not the bottom bracket thats touching.the part that hits the x pipe is the tube that goes up to the loop.my x pipe conects into an x after the hanger.
