Project 67mm build for a redneck
don't worry about them. Blow thru tb is different than draw thru.
The money you were going to spend on the tb might be better suited buying the sct pro racer package perhaps?
why buy the sct pro racer package???? I am no means a tuner nor want to fuck with that shit thats what i pay people for.
New gauge cluster SOS and AEM gauged
Vashthe3rd
Maximum Trolling
Looks slick. OOOH do you have the black face for your wideband still? I will buy it off you! I need one for mine
I just realized I've never told you how much I love and can relate to your sig pic lol.
(sorry off topic)
one eyed willy
Pizzle fo shizzle
Lakeland FL
i will agree with all on the AEM true boost, i was having some pretty bad spiking going on and tried everything i could try for a year to get it to stop....re-plumbed everything and tried a million different settings....
bought a e-boost and the problem went away with ZERO set up.....
I am so scared now of the aem true boost :(
but i guess i'm going to order new 80lb injectors so there's no worry about them being maxed out on boost
Fallenauthority
La Plata, MD
Did you mess with the WG crack setting? I had issues with my old one spiking but I adjusted the crack setting and it got rid of all the spike issues.
one eyed willy
Pizzle fo shizzle
Lakeland FL
i did, i tried every setting the whole year i had it....i got it better and better but was NEVER happy with it. it would always spike a few PSI if i was hitting the throttle very hard, it was like there was a delay to what it was telling the solinoid to do........e-boost fixed all that soon as it was installed on the very first time i tested. i tired everything with the AEM, re-routing all my vac lines, changing them all out.....i eliminated all causes to the spiking other than the AEM before i just gave up and replaced it.....and im so glad i did! e-boost adjusts boost based on RPM as well which the AEM does not do.
so haven't touched the car in a couple of weeks and got back on it today for a few hours,
new questions are i guess with the HP turbo kit i have to remove my front sway BAR???
and i moved the radiator up about 1/2 but the fans still seems kind of close to the hot side about 1/2-3/4 a in away.
And ideas about the sway bar people please and thank u
new pics
JoshK
Modder AKA Fuel
Nebraska
The hot side of my turbo is about 1/2" away from the fan schroud. Haven't had any problems yet and have driven the car at least 3hrs straight once so far.
JoshK
Modder AKA Fuel
Nebraska
THe on3 kit comes with two pieces of steel that allow you to lower the sway bar from its stock location a couple of inches which allows the up and down pipe to have enough room. I am not sure how this would work on your kit but you could take it lose and lower it down a little and make some brackets if it would work.
Best pic I could find, hope it helps.
one eyed willy
Pizzle fo shizzle
Lakeland FL
thank you
but swaybar??? i guess it is coming off?????
i have a set of sway bar lowering brackets if you need them....they put the top hole of the bracket onto the lower bolt and then gives you a new lower bolt for the lower hole in the bracket, let me know...PM me if your interested
JoshK
Modder AKA Fuel
Nebraska
that is exactly what I was trying to convey OneEyeWilley. You just did it better than I did(and had better pics)
AbdullaGT500
Little Rock, AR
I had to lose my front sway bar for the hp kit, haven't tried a sway bar relocation, but I'm planning on giving it a try once I get all my issues lined up. My turbo exhaust housing was touching the fan so I had to go with a slim fan setup. You should be fine if it has 1/2" since the fans will be running to cool it down. I would recommend a turbo blanket as well.
I have heard from my evo and subi buddies that the Turbo blankets are not really a good thing on a DD cause it will cause pre mature turbo wear, good for spooling and but keeps heat in
And one eye willy i will take thoses brackets
