Jeez, all of you hold your panties on.
I gotta work to afford these ridiculous projects.
Plan is to work tomorrow morning and take to the shop in the afternoon.
To Do List
1. Stop looking and actually work on the car.
2. Hoist up engine
--Remove Front Fan Shroud/Radiator
--Install 2013 GT500 Oil Pan/Oil Return
--Install 2010-14 GT500 Flywheel/Bolts/Crank Bearing
--Lay down A/C Lines.
--Drop the big boy 5.4 into the cavernous deeps of where a 3V used to reside.
--Mock up and install SS FRPP Clutch Cable
--Install 2010-2012 GT500 Clutch (decided to keep it)
I am missing a O2 sensor on one of the manifolds so hopefully I can get one tomorrow.
Sam if you are reading this.... does the GT and GT500 share the same 02 sensors in the manifold and cats? Forgot to look this week.
After the engine is in the car, then comes the fun part for me to locate what I am missing to complete this master piece. It is going to slow down for a bit since I have some other money priorities to take care of. If I sold that 3V by now, I wouldn't have to do this. So help me sell it and you get $100
Last big ticket items include:
C&R Radiator
C&R Heat Exchanger
FRPP Dual Fuel Pump
2013/14 GT500 1-Piece Carbon Fiber Driveshaft
MGW Shifter
In the mean time I need to do the following also -
*Remove Rear End and Paint it using self etching primer and gloss black paint. Remove and replace fluids/axle cover.
*Install all new suspension components -
Side note: Anyone with the BMR K-member need camber plates to counter act caster in the alignment?
*Install Spacers
*Install Brembo Brakes/Line Lock
