avinaj80
- Joined
- Feb 2, 2010
- Posts
- 1,479
- Reaction score
- 0
Awesome build Cam. Enjoy it.
The bypass valve is vacuum driven. When it sees vacuum, it should be open; when no vacuum is present, it should close. My experience with the blower is on my 3V with the DOB setup and there is nothing but a vacuum line from the manifold to the BPV. I don't know if there is a more complicated setup with the GT500 setup, but since lack of vacuum closes the valve, I'm not sure how there would be electronic overrides (I certainly could be wrong). I assume you've checked and double checked the vacuum lines?
BTW, awesome build! I haven't been on this forum a lot but I have been following this build. Nice job!
While vacuum has a lot to do with it, the throttle positioning is linked directly to it actuating open/closed. Such as when you are driving slowly it stays open but when you progressively get into the throttle it begins to shut more and more. The GT500's computer system can override this and that is how the cars came when they were brand new; in order for the supercharger to be activated you needed to do some assorted number of key cycles (25?), and the ECU would unlock the functionality of the blower. I've seen a problem before where the ECU has locked off the bypass valve from functioning correctly on a GT500 and I am trying to figure out if that is what's happening to me. Thanks for following the build! Hoping to fix this shit and enjoy the car. I love driving it.
Ah, that makes sense. So while the BPV is still just controlled by vacuum, since the throttle obviously controls whether there's vacuum or not they can indirectly control the BPV by the ECU via the throttle.
This reprogramming stuff all sounds pretty complicated so I hope you can get it figured out so you can just get out and enjoy the car.
Fixed!BTW Sam, your PM's are full.
Congrats on the victory today! That had to feel VERY good!
Fixed!
Hell yeah Cam! That motor looks damn good sitting in there
Awesome news about the codes! Keep us posted about the Aeroforce gauges. I was just about to order a dual gauge setup. I may wait a bit now...
Cam, good work troubleshoot the problems, I new you figure it out.
I've owned AF gauges before and never had a problem like this. I'm just pissed off since I need them to work so I can detect my vac/boost for this supercharger problem. I left them an email but will be calling tomorrow for assistance.
Glad you're making progress.
Is it possible for something to be in the way of the bypass valve preventing it from moving through it's full range?
Do you have a number for them?
I tried calling them before. The only number I could come up with was disconnected.
I tried getting in touch with them on their Facebook page, they kept linking me to their web site and the online manuals.
Apparently they don't want any phone calls
