It needs some STACKS!!!! HAHAH! I'm so fucking glad you bought it so I can say that to you!!!
It's hard to picture you driving that truck though, it's sort of ... farmerish.
Haha, I knew I had that coming. No stacks here though.
Everyone has found it pretty comical since I'm always driving a new vehicle and when I pull up to work wearing wingtips and an asshole shirt it doesn't compute. However, everyone absolutely loves the truck and I can't go anywhere without striking up a conversation with a stranger.
Nothing major, but it does need a good amount of TLC. Biggest thing is that the frame is solid and the engine is very healthy.
So far my list includes -
*Swap rear gears to 4.10. This truck came with 3.55's
*Dana 60 Swap from a F350.
*New shackle mounts in the rear. They've rusted through
*Needs new rotors/pad and possibly one caliper.
*I would like to convert the rear to disc brakes
*Refinish the factory Alcoa's and put on new tires
*Needs new lower cab corners. The driver side is rotted out pretty noticeably.
*Needs a new front core support since the bottom parts have no weep holes and water builds up and rusted them out.
*Replace the dash bezel since the tabs have broken off
*Needs a new column shifter plunger
*Probably in a year I'll pull the engine to replace the oil pan since it shows minor seepage.
*Straight piped exhaust. No performance until I look closer at the engine. It's got 382K and I don't want to push an engine that's never been tampered with at that age.
I do plan on keeping it for a long time so I'd like to tear it down one day to the frame and put it back together.
A lot of work, but I'll accomplish it over time. I love driving it as is.
