2DaDarkZide PR
Vroom, Burble, Burble
Had Tillman speed install my Pypes LT headers, off road and retighten my axle backs.
It sounds great. Looks great. Feels like a nice bump in power. Smells like fuel
http://youtu.be/mzmZ_PLkfOA
Only 2 things regarding it.
1. Fitment was decent but not perfect. The header touches the steering. It is little by little making a groove in it. It also would vibrate when hitting on this 8MM bolt that holds on this thin, aluminum shield, dust shield probably held on by 3 bolts? The bolt was long enough to hit/scratch the passenger header when you hit a bump. I removed those two shields, one from each side and now there is no vibration or rubbing except for the steering. I make try and bend, (NOT dent), the header ever so lightly to give enough clearence.
2. I noticed the header is one piece, the x pipe another and the axle backs are the last part of the "full exhaust" but what about the part that goes over the axle? That always gets re-used? It is crushed bent over the axles which have to impede flow, no.? What would this section of exhaust be called? Can I buy a piece that bolts up to my Pypes mufflers and shorty x pipe?
