Hey Steve, I need some advice and some pricing. I noticed my car beginning to over heat a bit while driving so I replaced the radiator, water pump and thermostat. Well It was still getting hot. I tracked down a issue at the BEC and Noticed the contact for the high speed fan was slightly melted. I can only assume that with my car being 10 years old that the original fan is drawing too much current and melting that contact. So here is my question will this http://www.tascaparts.com/ford/must...stem-cat/cooling-fan-scat/?part_name=fan-assy
fit for my 2005 mustang gt? I am pretty sure it will. Also I read some on here are using the fan from a 2013 GT500 to get some additional cooling for their GT's. Do you know if it is a drop in fit or will I need to order additional parts (resistor) and what are the prices of both of these fan assemblies? Thanks.
