Race stars
silver rhyno
Texas
Thinking about a 17x7 and a 18x10.5 for my 12 track pack car..any fitment issues? Any pics out there of this set up?
Scott
King City, Ontario, Canada
17x7 fit fine on my 08 with 14" Baer 6P Brakes. I went with 15x10 in the rear. This pic is with the Air Lift suspension aired out.
dv8uagain
Worthless
Philadelphia, Pa.
Scott I am pretty sure we run th same tire out back the 295/55/15 if I am correct but what are you running up front did you stick with the 28 is tall tire or go with a 26?
Scott
325/50R15's in the back. Differential has been shortened to tuck them in within the fender line. Fronts are BFG Advantage T/A's 215/60R17's which are about 27.2" in diameter.
Hiltsy845
Scott, are you running the stock rear sway bar? If so, does the inside of tire rub the bar at all?
Hiltsy845
Thanks for the pics. Do you know if the arms on the Steeda sway bar are closer together than on the stock bar. I am narrowed 3/4" per side, but my 28x13.5-15 QTP rub slightly on the outside of the arms. I don't have much room between the sway bar and the LCA relocation brackets either. A Whiteline style rear sway may be my best bet.
Your car looks great BTW.
Scott
Matt I don't know if there is a difference in the OEM and Steeda Sway Bar arms, sorry.
Have you considered eliminating the sway bar with a BMR Xtreme Anti-Roll Bar?
Hiltsy845
I do a few road course days each year, so the ARB wouldn't work for me. Thanks for the suggestion though.
