Rear bumper cover gap
Mrerob
North Alabama
1F2038F9-4059-4D96-BD73-31DEA80FDA1F.jpeg I am new to this forum, this is the first mustang I have owned ‘10, but I have been had Fords my whole life. My bumper cover is separating from the car like the tabs are broken idk if there is a way to fix it or if I just have to get a new one, one of my friends that worked at a ford dealer said it was caused by airflow, I did back up on a curb literally the day I went to get a tag for the car like a moron. Just curious if anyone else has experience with this issue
MrAwesome987
Upstate SC
I think there is a guide pin/plastic rivot thing from the bumper to the body of the car accessible from behind the plastic trim inside the trunk. I had a similar issue and found a nut that would thread onto the pin - that helped to pull the bumped up a bit.
bujeezus
Alabama
I replaced mine last year after a hit and run at a stop light. I don't know what MrAwesome is referring to. Your's looks like it just popped out of place.
Mrerob
North Alabama
I’m not sure either but I’ll have to lookin into that for sure, it has 1 or 2 of those clips broken on the bumper cover, it was popping out and I would just knock it back in, but I tried yesterday and it wouldn’t pop back.
Iceman62
Bullitt 6005
NE
Those plastic seams have little tabs (as you see/know) that must catch to hold. If enough tabs are still good, it should pop & hold, but you have to get the cover loose in other areas to manipulate. Take a good look at where these parts are secured & find the bumper cover screws/tabs. Remove them on bottom & then pop it into place...you might end up taking the entire cover off...
If too many tabs are broken, go to a salvage yard & find a replacement (same color, hopefully), or time to add a sweet rear ground effects to your ride. Good luck!
Mrerob
North Alabama
I was thinking I might have to do something like that, (taking the whole thing loose and readjusting) I had ACL reconstruction surgery 3 weeks ago so I’m not able to ATM probably be a few more weeks when I do and I’ll post an updated photo, try and see what all I have to do to make it look a little better if I’m able to, thanks.
Iceman62
Bullitt 6005
NE
Been there/done that (ACL procedure). Listen to the Docs, don't over-strain the knee & Physical Therapy is your friend. Get well!
