Recommended radials
black N boosted
Boosted
Perkasie Pa
Just ordered the racestars today and tring to find the right tire size and brand i should go with for the 15x10 and 15x3.75........ last season i ran the 275/17 m&h's so i was thing of going with an opposing brand!
shatter
White And Nerdy
Northern California
Graypny started a thread on this a couple of months ago. I posted a car and driver article where they did wet and dry tire testing with rankings of around 10 different tires. It's a place to start from at least. :)
don_w
Dyno Numbers - Who Cares?
San Diego, CA
C&D did an article about drag radials? Really? I'll bet the wet testing wasn't so good. hahah
To the OP: M&H and M/T are both proven performers. Can't go wrong there. Avoid the Nitto 555R (but the new NT05s might be better). And I'd be tempted to try the new Goodyears, too.
shatter
White And Nerdy
Northern California
LOL, I just looked at the title that said RADIALS. I didn't pay attention to the M&H brand which would have clued me in on he wanting DRs.
N
navbtcret
Guest
I have aset of MT 295/55/15's coming that should be here next week. I am putting them on the racestar 15x10's.
I will be running the MT sportsman radial on the front, on the 15x3.75's. I have that tire in hand and will get them mounted on the rims next week.
275/60-15 from M&H, Mickey Thompson, Goodyear, or Hoosier.
SD
why a 275/60 vs the 325/50 from M&H?
I'm thinking of getting this set up as well and am unsure what rear tires to go with.
275/60 M&h
325/50 M&H
295/55 MT
black N boosted
Boosted
Perkasie Pa
there the sizes i was looking into also... tring to see what kinda fronts to run also!
SD
275/60 M&h
325/50 M&H
295/55 MT
US-1
Banned
The ShadowLands
SD
275/60 M&h
325/50 M&H
295/55 MT
Kind of a "generalization" on tire selection. M&H is an anomoly. Their tires actually run more narrow than anybody else's stuff. The majority of 325/50 tires stick out of the car so they look like shit and sometimes just don't work right. I've got the 325/45-17 M/H tires on my car with a 9.5" wheel and it looks like a 275/60-15 on an 8" wheel. You can't tell there's a D/R on the car from a casual glance. The 325/50-15 M&H will look a lot like that too. The 295/55-15 from M/T is pretty much "in the middle" of those two choices as far as fitting under the car and working properly.
Any of the three will work but for a screw blower car I'd get as much tire as possible on the ground without it hanging out from the side.
don_w
San Diego, CA
I was under the impression that M&H has changed their sizing over the past year. Like you, I have an older set of 325/45-17s on 17x9 wheels(for the street). I think their current sizing is more realistic.
The "new" M&H 275/50-17 has a tread width of 9.5" and a section width of 10.5", which is about what the old 325s were. The new 325/45s are 11.3" tread and 12.6" section. I personally wouldn't put that on a 17x9.
As far as their 15s go, the 275/60 is 9.5" tread and 10.9" section... an 8" or 9" wheel should be fine. The 325/50 is 11.0" and 12.4". That would probably be good on a 15x10 wheel.
SD
Thanks for the response. I guess with a centri set up one can use less tire, I guess I'll have to decide between a 275/60 or 295/55
