Do y'all have issues passing emissions test in Harris County? I'm thinking of getting the KB SC installed by Strictly Performance, but my car's a DD, so this is a major concern, because it has to be street legal.
Thanks.
Thanks.
Well I live in the DFW emission counties (Collin) and I have no trouble passing inspections either with my Saleen SC.
Be sure your tuner leaves the back two oxygen sensors on in the tune and you will be fine as long as there are no codes in your system or the CEL is on when you take it in.
Also, you need to be sure the car has been driven for a couple of weeks or 200 miles after a PCM reset (pulling battery cable will do that), to ensure everything shows "ready."
Hope this helps.
PS: Don't ya just love those $40 yearly inspections!?
Mike
Mike
Mine are turned off in the tune and it passed with no problems.Be sure your tuner leaves the back two oxygen sensors on in the tune and you will be fine as long as there are no codes in your system or the CEL is on when you take it in.
Yeah...but our roads are better for that extra money. Plus, we have considerably more roads.What I love is the $60 a year for registration, in La. it was $50 for 4 years
Hmmmm... SC and low octane. Not normally a good mix IMO.Maybe when I get the SC and a dyno-tune, I'll ask Strictly to make ... a "low-octane" tune...
For emergency purposes...like in the aftermath of Ike....no premium gas...Hmmmm... SC and low octane. Not normally a good mix IMO.
Good info, thanks Matt.In Galveston and Harris counties if the OBII machine cannot read your OBII port ( if your OBDII port is broken or you pull the fuse) it will kick directly to the dyno sniffer. If you have cats this should not be a problem.
Maybe when I get the SC and a dyno-tune, I'll ask Strictly to make a "regular tune", a "low-octane" tune, and an "emissions" tune....
If you let someone like HPP install/tune your car, you won't have to worry about passing emissions!
Hope this helps.
Mike
