Rocker Arm inspection
4 im here again
Brea, CA, USA
Hi there!
I just got to see my rocker arms. They have a bit of movement side to side and i could try to twist it and it moves a tiny bit. Im wondering if this is normal state for the arms as all my arms are moving like that and the gaps seem to be uniform. Wanted to get check to see if they need to be replaced. Some of them have slight scoring mark but its very mininal. It shows similar scoring marks on the cam lobe also. but also minimal. i used a steel pick to feel the damage and I could pick up a tiny bit of resistance at the line but most are relatively good. Any thoughts?
Rocker arm piston 4
piston 6
light scoring
