EagleStroker
N/A Junkie
Issue: rough idle, idle RPM will jump to 3k RPM, fall to 500, and continue to drop until it completely chokes the car out. Normal idle is 8-900. This started out of the blue, one day car was fine next it wasn't.
Attempts at fixing it:
1) checked, no vacuum leaks that I can find.
2) thought it possible to be the throttle positioning switch due to no pedal response. Checked and pedal was showing voltage without the throttle depressed. Replaced, throttle response is fixed but idle has not.
3) MAF. This was the first thing I checked. Unplugging cause no difference. After replacing the pedal it would smooth out the idle. Replaced, no effect on idle.
4) No code at all is tripped while this is occurring.
5) Just replaced fuel filter.
Usually at this point I would tow it to my shop. The shop that tuned my car no longer takes in work and it's left me uneasy dropping a problem off at someone elses doorstep.
