Roush Exhaust Blew up?
WJBertrand
Rodent or packing materials in there could have supplied the "fuel". If the engine were running properly, and the catalysts working as intended, there would normally not be enough fuel downstream of the cats to cause an explosion. If there was an air leak in the installation, alternative fuel source and super heated gas coming from the cat - BOOM!
06 T-RED S/C GT
Carnegie, PA
That could indeed happen if the PCM went into a COT prevention event (catalytic converter overheat...PCM will increase fuel amount into the cylinders on the specific bank to attempt to cool the overheated catalytic converter substrate in addition to cutting ignition timing as noted by the exhaust temp inferred from the rear O2 sensor heater circuit readout of the affected cat...OEM tune set @ 1,650*F) & since the Roush catback exhaust uses resonators in mid pipe section they can trap excess fuel vapors in them (these are an expansive type of sound control.....it's in the picture just ahead of the damage) & it can flash off if the resonator got hot enough & enough free unburnt O2 was present in the exhaust to promote the "rapid expansion" as these are close enough to the cats to retain enough heat from them (cats at speed under an OEM tune put off approx 1,200*F-1,300*F but if tuned for performance can get in excess of 1,400*F-1,500*F + depending on conditions.....mine for example currently run around 1,430*F-1,450*F at speed @ FBO\cammed\tuned NA 3V thru Kooks Hi Flow Race cats....highest I've read thru a scan tool was 1,437*F) to ignite the unburnt air\fuel mix. Engine misfiring at speed can set this up as well if it is severe enough (dumping unburnt air\fuel mix into exhaust causing cats to overheat from having to burn off the excess air\fuel thus set off the PCM to go into COT prevention) but if this was the case the PCM should have set the MIL flashing......if the misfiring counts exceeded the threshold. Might check the PCM for any pending codes\Mode 6 Misfire Monitor data for any recorded cylinder misfires that could shed some light.........
The piping shows signs of overpressure from within & the materials most likely came from the Roush resonator...........
If this was the std OEM catback exhaust layout (nothing installed in mid exhaust piping post cats...mufflers are mounted at rear of car at end of exhaust piping) then this would indeed be very near impossible as the exhaust temps would have greatly dissipated by the time it got to the mufflers (next place to potentially trap any unburnt fuel vapors) but w\ the Roush catback exhaust system (or any mid muffler\resonator catback exhaust system w\ cats still being used w\ the rear O2 sensors still active so the PCM can go into COT if it deems necessary) this can occur if the conditions are right.
Not saying that this is the culprit that caused this particular instance w\ the OP's exhaust but this is possible w\ these S197's that are still running cats w\ the rear O2 sensors active w\ a resonator\muffler mounted in mid pipe section.
Something to keep in mind for those of us who are still running cats & use a mid mounted resonator\muffler catback exhaust. Also why you also should be mindful of how your engine is tuned when cats are still being used to stay out of COT. Those that are running a FF exhaust setup.......won't typically run into this....unless the rear O2 sensors are still active & COT is still active in the tune then this still "could" happen depending on how hot the exhaust is (think FI at this point) at the mid mounted resonator\muffler....
Agree w\ Mr Awesome987.....OP needs to pull & inspect all of his exhaust to get the full extent of the damage then once any repairs are made to the exhaust I would have the engine & engine management systems checked to ensure all is good.....IMHO something had to get out of spec to cause that to happen......Roush may warranty\replace this part but be prepared if they don't.
PS--For all those that like the crackles\pops from the exhaust upon decel....that's from the engine pumping unburnt O2 into a heated exhaust w\ some unburnt fuel vapors still present so don't think it's impossible.....some folks tune their cars to do this............
First off! The Roush mid-resonator catback exhaust was designed to be used with the stock catted mid-pipe in place. Therefore, I don't buy in for a single moment about the resonators being mounted just before the rear axle as a contributing factor for causing catalytic converters to overheat. If that were in fact the case? there would be far more wide spread complaints rather than just a few isolated issues. Actually, up until the OP posted his recent experience, I don't recall coming across any other posts regarding an exhaust system component exploding from a catalytic converter overheating due from installing mid-mounted resonators lol. Another reason I don't buy into your claim, is prior to the debut of the S197 Mustang in mid 2004, the exhaust systems were all designed with the mufflers mounted before the rear axle. Perhaps it's possible the OP's issues were related from an improperly calibrated tune, but that's also highly doubtful, as installing a mid-muffler/resonator cat-back exhaust does not require any additional tune modifications. That being said, I stand by the previous post regarding the OP's issue was more than likely caused by either a manufacturers defect or possibly from some form of road construction debris :shrug:
Also note that all factory exhaust systems for the Coyote 5.0 cars include resonators!
86GT351
Sunny South Florida
Unless he can all but prove that a manufacturing defect was the cause of this, I don't see Roush doing anything for him, even if he bought it new and had the receipt. But I have never dealt with Roush customer service before.
Probably true.
Iceman62
Bullitt 6005
NE
Where's the OP...better pics needed & was the cat-back new, or used?
MrBhp
I'm guessing that there was never any damage and it was just something melted onto the outside...
I'm guessing that system is no where near new. Several rust spots around that "blowout". This thing was rotten when he bought it.
WNYGT5-0
DogTown, NY
My bet here is that he bought a second hand exhaust that someone had stored with some plastic bags shoved inside to keep critters and stuff out. Installed without removing the bags. Bags melted...blew a bubble... the bubble popped.
06 T-RED S/C GT
Carnegie, PA
Yup! the bubble popped and then went
:laughlots:
