RPM's
mp 2010
Why are my rpms dropping almost to the point of shutting off when I come to a full stop?
2kanchoo
I'd suggest cleaning your MAF sensor as well as your TB. Just make sure you use the proper cleaner on it.
mp 2010
when you say clean the tb you mean just pulling aside the intake and cleaning the area before the blades or do i need to take the tb off and clean further than the blades...sorry for the rookie ass questions but i just never actually done it.
2kanchoo
I'd start with the MAF sensor. Unclip and pop it out. See if it looks dusty/dirty, give it a cleaning, pop it back in and see if that fixes the problem. That's a lot less work than getting all up in the TB.(Not that it's overly hard).
mp 2010
Ok well thanks it'll be a day or two till I can get to it considering it's new year's eve. but I got the idea with your advice and the video I just watched on how to clean tb's on youtube I think i can handle it...if any problems I'll let you guys know but as of now...HAPPY NEW YEAR to everyone enjoy your night but be safe and thanks for all your help I'll post results in a few.
DKO
Shut up and die!
The Dirty South, South Carolina
Also consider changing the fuel filter. It's like $10 and ford recommends you change it every 15k miles. I had a similar problem with my car and I cleaned the TB and replaced the fuel filter at the same time. Can't tell you which did the trick, but both are considered standard maintenance.
scramblr
New Braunfels, Texas
Fuel filter change is every 30k miles, but good point since he's over that anyway.
DKO
Shut up and die!
Pretty sure it's every 15k. I don't have my owners manual in front of me but it's really sticking out in my head that it's 15k. Whatever the case, that thing gets stopped up quick and it could benefit from replacement.
2k05gt
Manassas, VA
+ 2 on all above.....
Make sure you get both MAF Cleaner and TB cleaner.
The Filter is located Under the driver's seat, effectively, on the bottom of the car. It's hiding under a plastic cover.
http://s197forum.com/forum/showthread.php?p=170024#post170024
For Part Numbers: FG-1083
http://www.fordinstallersupport.com/files/catalogs/filters.pdf
Don't Forget to replace the Cabin Filter as well
Bosch part number is P3756 $18.99 Autozone
Here is one online with replacment instructions
http://www.mossmuscle.com/Shop/ViewProducts.aspx?PlateIndexID=54251&SortOrder=1
JimmyD
NJ
Exactly! And from what I've been hearing, plus my own experience, I'd change it at 10k They do seem to clog up real quick.
psycho bob
FISTER
Tulsa, OK
it's not like the thing is expensive or hard to change either. it takes all of like 10 min. if you include the time you spend either jacking it up or pulling out a ramp for the front drivers wheel
