5w30 here as well i run 7 quarts with the oil filter relocation and larger f1a1 filter
I always use the Motorcraft, as it is cheap and recommended as an OEM replacement. I heard the Mobil 1 filters are supposed to be better, but I haven't seen any data to prove it. I am always up for trying new things and I do have a lab here to analyze my oil if needed.
Think I read it on here but it was something along the lines that if you're FI then you should run thicker oil. Whats up with that.
http://www.synlube.com/sae5w-20.htm
so i get a bit of information outta this, but whats the deal with the second number in oil ratings? can i get away with 5-40?
I fought a long argument on another Mustang forum about this topic. So many people were giving out incorrect information that you have to use 5w-20 or it could damage your engine. I had to educate them about the meaning of the numbers and why you can use other oils. I stick with 0w-30. Better fuel economy and less resistance. When I start autox, I will probably go for some 5w-30 or 5w-40.
LOL. Guess what the Mustangs sold in Europe are spec'd to use? 5w30!![]()
