Mineral_'01
- Joined
- Aug 24, 2014
- Posts
- 183
- Reaction score
- 1
^Lower CG with an LS too...
I'll have to weigh the pro's and con's of a LS vs a Coyote. It will mostly come down to cost. That said making 600 out of an LS is a lot easier than 500 out of a Coyote.
So what?
How long before official pricing on the GT350? Any word on what trans is in it?
I heard TR3160...not sure of the reliability of that source, however
Making LS power and cubic inches is just stupid easy. Ford did us NO favors with the crap bore spacing of the mod motors. A baby LS is 5.3 liters. You can pick one up on the street in front of the junkyard at 3 for $100, it seems like. Meanwhile, if you want a 5.3L Coyote, it's a $20k+ proposition. I've got a 370" Rodeck chevy lurking in the corner of my buddies shop, just biding it's time, waiting for my Coyote to barf.
It's no mystery why Superchargers are so popular in the Ford camp.
I'm pretty much thinking it has the be the 6060.3160 is rated at 310 ft/lbs??
Hoping for TR6060 w pump
what is this w/pump we are talking about? does it have a pump to circulate trans fluid? like mabey to a cooler or something?
Just some info I have been tracking thus far.
Making a list here. Will have more parts soon - just needed to start keeping track!
OEM Front Subframe (K-Member): 58.2lbs
BMR Street/Handling K-Member:
BMR Drag K-Member:
OEM Rear IRS Subframe (Empty): 55lbs
OEM EPAS Rack: 36.46lbs
OEM Motor Mounts: 3.9lbs - each
OEM Rear Lower Seat Cushion: 11lbs
OEM Windshield Washer Fluid Res. w/ Fluid: 9lbs
OEM Battery: 31.31lbs
Deka ETX18 - 17.67lbs
OEM Catback Exhaust: 72lbs
Magnaflow Comp CB - 44lbs
OEM Base 18" GT Wheel w/ Tire: 54.5lbs
OEM PP Model 19" GT Wheel w/ Tire: F-60.6lbs / R-64.3lbs
Billet Specialties 17x4.5 w/ MT SR 28" Radial - 39.8lbs
Billet Specialties 17x9.5 w/ MT 28" Drag Radial - 51lbs
OEM GT Cloth Seat: 50lbs
Corbeau FX1 w/ Bracket - 21.7lbs
OEM "Mid Pipes" w/ Cats: 22lbs
MAK O/R Pipes -
OEM GT Base Front Brake Rotor/Caliper:
Aerospace Lightweight Street Brakes -
OEM GT Base Front Rotor:
OEM GT PP Front Rotor: 33.4lbs
OEM Front Sway Bar: 12.7lbs
OEM 2-Piece Driveshaft / Auto:
OEM 2-Piece Driveshaft / Manual: 36.2lbs
Shaftmasters 1-Piece Aluminum DS - 19.09lbs
OEM Tire Air Pump: 5lbs
I know, I know.... no one in this section will run 4.5" wide fronts....but I will add the HRE and CCW weights, R888's...BFG, NT....etc when I get them.
