sct tune stopped in the process...car is down
thundr306
PA
Called into your service dept and told me to contact sct. Well they are closed and i had to fill out an emergency contact form. Said they will contact me within 24hrs, but my car is dead.
If anyone has any info, im more than willing to listen.
Sct itsx tuner, was on my 93 tune and wanted to load 91 tune, it connected,let me choose my tune, started the download, then said programming unsuccessful...message timeout.
Now i cant do anything. When i turn the key on, it acts like its in the middle of a download. Cant load any tunes or even read codes.
I've heard the SCT units are voltage sensitive. Some people recommend hooking a trickle charger up to the battery while loading tunes.
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
I don't have the fancy SCT you've got, but my SCT X3 has done this a couple of times before. What I did to fix it was to disconnect the negative battery terminal on the battery. Turn on the headlights. No, they won't come on, but it will help to discharge the electrical system. Left it like that for 20 minutes. Turn off headlights and hook the battery back up.
While waiting during the above, I deleted the tune files off my tuner. Don't delete your stock tune file though. I then reinstalled the tune files after renaming them onto the SCT tuner. Hook it back up to the car and viola, it worked! The next time my SCT froze during an upload, I did the same thing and it worked again. Now, my SCT hasn't frozen up again in over a year.
I don't know why this works, but it has on my Mustang, a friends Mustang and also a Ford truck. If it works out for you, then you've got your car back. If not, you're in the same place you are now.
Good Luck!
thundr306
PA
Thanks. Im going to try whatever I can. Need to go get a laptop amd cable to tie into this.
dmhines
KONA GT
Cumming, GA
I have had this problem with my iTSX. I discovered if I tried to load a tune immediately after car was running it failed. Pretty sure it had to do with the retained power feature. If retained power goes off in middle of tune load it craps out. Park car and let sit for a while with driver window down. Now do all programming by reaching through window. Do not open door. First set car back to stock then load your custom tune. I had same thing happen to me and this fixed it.
thundr306
PA
Ok, just got back.
I tried dmhines idea since it would be quicker, but it did not work.
VTXfrank...I downloaded the sct software so I could move my files around. My tuner came with the three custom files already loaded onto it, so I don't have them save on my computer anywhere. When I move the files from "on device" to "available tunes" it says it will delete three custom tunes. Since I dont have them anywhere else, I am assuming I will lose them forever or until Bama opens back up.
thundr306
PA
I don't know if I conveyed this in my first post but, as soon as I turn the key on(even without the tsx plugged in) the car acts like its in the middle of a tune...warning lights, bells, red dash lights, etc.
thundr306
PA
So much for SCT within 24hr emergency service...contacted twice since 2:30pm yesterday with no response.
thundr306
PA
Still no response...lucky I dont need it to drive to work tomorrow.
VTXFrank
Obama SUCKS!
Yeah, being a holiday weekend, I doubted you'd hear anything back. That sucks tho. I bet you really wanted to be cruising around in that bad boy this weekend! I know I've driven mine a lot.
thundr306
PA
I didnt expect someone to be waiting for my phone call, but they claim an emergency service for broken down cars.
AMWill
AmericanMuscle.com
Malvern, PA
Sorry to hear this thundr306! I'm surprised the battery drain technique didn't work. Have you been able to contact SCT today?
Let me know if you still can't get a hold of them and I'll get in touch with them myself. I want to get your Mustang up and running ASAP!
Shane
thundr306
PA
Shane
Edit: car is still not running. Been in contact with SCT.
thundr306
PA
I finally got a loaner tuner with my recovery file via Fedex. The car now starts and runs on the factory tune. Now I have to send my iTSX and the loaner tuner back and they can try to figure out the issue.
AMWill
AmericanMuscle.com
Malvern, PA
Good to hear the Mustang is up and running!
I also sent you a PM. Get back to me at your earliest convenience!
Shane
thundr306
PA
Got my iTSX back yesterday. Luckily I saved my tunes because they were gone off the tuner. Car is up and running again, but I still have my doubts.
weather man
Persistence Is A Bitch
MN
Nobody likes it when electrons start doing their own dance. Hope things keep working.
