Ok so I installed a turbo in my car, and we were having a bit of issues tuning due to the throttle body wormclamp coming loose under boost and throwing the af ratios off. Yesterday I was on my way home shifting under 4k rpm, car is on a rich tune for the meantime, when all o a sudden I hear a shuffling card noise. It was a really loud noise at a very rapid speed. I let off the gas, in neutral, and the car just stayed idling but making the noise. We checked out the noise and found out it was coming from the valve covers. We took the valve covers off and inspected the cams, followers etc. The cam lobes had no scratches and the followers looked perfect. After some research on youtube, we found the phaser lockout video by livernois, and we matched the sound exactly. So I ordered some phaser lockouts and bolts from bbr overnight and I'm just thinking about removing my cams and putting the stock ones back in. I'm not forged and I have nsr stage 2 cams. I was wondering what you alls opinions were; keep the cams and run 6psi, or remove the cams and run 9psi? If I do remove the cams I can make back some money I've invested in the turbo build. Thnaks for the input.
