07gts197
I noticed more and more effort has been required to shift recently to I took the boot off the shifter and shoved my phone with the camera on down the hole into the trans tunnel to find the bolt that holds the shifter arm to the side of the trans worked its way loose again. Long story short I share my car with my dad and he didnt like the tri ax I had in there so I put the Hurst shifter back in then sold it and went back to the factory setup but in doing so I cross threaded that bolt so it wont snug all the way now. I torqued it down the best I could yesterday and got it 90% of the way in but I know it needs to be fixed. Has anyone run into the problem of it constantly loosening on its own? This isnt the first time. And what can I do to fix the threads? Will a thread chaser work in this case? What about the bolt size and thread pitch?
