Shock Tuning Help
psfracer
billy badass
Valencia, CA
I'm hoping to scrape together some spare change this winter to get some fresh rubber on the rear, thinking of going with the a set of Hoosier Quick Time Pros, 28 x 13.5-15LT. I think I've seen someone on this forum fit something similar in size under their car.
The video looks great! What size rear tires are you using?
The slow motion shot at 2:39 looks really cool. Almost no rear movement when the car launches, but then at 2:42 it looks like there's a good bit of rear fender separation. How much anti-squat are you running? Are you still using a 3 link setup in the rear?
Yeah that was only because the anti sway bar wasn't adjusted properly that day on those passes, and the driver front was coming up higher than the passenger front. The launches with the Bogart D10s without beadlocks were with the 3-link, the D10s with the wider tires and beadlocks were with a ladder bar set up. I would say look at the launches at :23, :39, :47, :59, 1:10, 1:20,
