OK, getting back on track. Here's a basic starting list for my planned build-
FRPP Aluminator shortblock- $4600 (Tousley Ford)
FRPP high flow heads- $3000 (Tousley Ford)
VMP TVS1900 blower upgrade for the M90 setup- $3600
Associated hardware, gaskets, etc. needed for the swap- $1200
FRPP Hot Rod cams (already bought)- $500
Rough budget for parts = $12,900
I'll help with the labor but the majority of the wrenching will be done by my trusted mechanic, simply because I don't have the space or tools for it. I'm budgeting $2000 for labor although I'm sure we will do some sort of swap out for much of that.
My original idea was to to the blower first and pulley it at 8-9 psi, then crank it up later after the build. I may still have to do that, as higher boost will require additional upgrades such as bigger injectors and fuel pump which aren't in the list above. Boy, power sure is expensive!
