As stated, I replaced the clutch master cylinder in my 05 GT. Man what a pain. Regardless, I got it done. With there being no way to really bleed the clutch (Seems it is self-adjusting / bleeding) I figured that the soft pedal would pedal would be gone in a day or so, after countless pumps and a tired leg.
Anyway, here it is three days later and I am getting a really irritating squeal when depressing and releasing the brake pedal while running. Imagine a person letting the air out of a balloon while pulling the opening to vary the pitch, same noise.
No noise when depressing or releasing the clutch, only the brake. Seems like the clutch cylinder may be pulling and pushing air. Anyone ever seen / heard this before? I read that even though the clutch and brake use the same fluid reservoir that the compartments are separate.
I have ordered a new vacuum pump (Cant find my old one) and will try and pull the air out again this week. I did try the trick of jacking the rear drivers side a bit to help while pumping the clutch with the cap off to allow the air to escape. Does not see to help. Any thoughts?
