Instead of a torch you can actually put a socket on the bleeder and while trying to turn it, tap the caliper housing lightly with a hammer. I have done this in the past and it has freed up a bleeder screw.
... I'm curious how you could contaminate the entire brake system (or much less any part of it) by using penetrating oil on a hole that serves exclusively as an out hole?
*Sigh.... Obviously none of you guys have ever had to replace every single rubber component in a brake system cause some knucklehead decided to soak his bleeders with PLP and it worked its way into the brake fluid.
I know its not likely but it happens. This particular vehicle would lock up the brakes after driving only one block. All the hoses, master cylinder rubber and abs unit were all swollen up on the insides.No, we haven't. Because that's ridiculous. "sigh"![]()
That's a good idea about clamping off each caliper, unfortunately I only have 2 clamps and that would only work on the rears. Oh and the rears are stock. I would need to purchase 2 "quad pad" spreaders to complete the test.
I have had to replace all Rubber components because other fluids besides Brake FLuid got put into the Master Cylinder. Very Expensive Mistake.
I meant people putting the wrong fluid in the Master Cylinder. Once it gets into the system, all the rubber gets contaminated and swells.
A little PLP wouldn't probably be a big deal honestly. That one vehicle that had all the bleeders bathed in the stuff was what completely turned me off the idea of using any at all you know? OP its too bad you werent around my area I wouldn't have a problem helping you out.That's how I understood your post. It's K_Brogoitti's comment about how spraying a little penetrating fluid on the bleeder valve is going to contaminate the whole system I find hard to believe.
