My buddy's girlfriend snapped them. If I had known, I would have spent more time doing my hair...
That body roll is WITH Strano's adjustable sways front and rear, AND on 350lb/in front springs, and 300lb/in rears, so the car's pretty stiff. You may have noticed that I bounce off the berms, rather than ride over them. I was also surprised by the amount of body roll, but I won't even consider running stiffer springs unless Sam chimes in and recommends it... Yes, I know that the dampers are a big part of the equation, but the whole package just f-n rocks. Sam was 100% right on the money about what it would take to match the suspension to my driving style, intended usage, and track types that I run. I can't say enough about his bars, or his customer service. Between the adjustability of the bars and the dampers (AST ROCKS!!!), I'm actually able to run square tire pressures, and have the car set up perfectly for my likes... Slightly tight in, neutral mid-corner, and slightly loose out. Nirvana, especially on higher-speed corners. Slow, tight corners are still wrecked by sheer mass, unfortunately...
I'm running 275/35-18 on 18x9.5 (+35mm) wheels. R6 for dry track, and Dunlop Direzza Star Spec for wet conditions and street driving, all in the same size.
I can say with certainty, that I am still learning to explore the edges of the envelope with the new suspension and R compounds, and I bet I could find another half-second or so in that lap. With the right hardware, and driver skill (still working on that!), this is truly an amazing chassis... Seat time above all else, though! It's taken me almost a full season to get really comfortable and TRUST the grip, but now that the trust is growing, I'm seeing my lap times plummet downwards. Yes, since July, last visit to that track, I've pulled 125lbs out of the car, and corner-balanced it, but that is NOT the reason that the times plummeted by 2.5 seconds! 0.5-1.0 seconds, yeah, I could see that, but the rest is me deciding to put on my big-girl panties and go drive the damn thing. I can't WAIT for Putnam next month!!! Smoother track, more elevation changes, and the best part: SWEEPERS AND CAROUSELS!!!! That WRX doesn't stand a chance! HAHAHAHAHAHAHAHAHAHA!!!!!!!!
