Somethings Knocking
LavaSlide
2012 GT LAVA
Gun Barrel City, Texas
Not sure what you were hearing but mine started to have a knock when it was warm and on a restart. Could not ever get it to do this on a cold start. The dealership was able to duplicate it. The performed a TSB regarding the chain tensionors. I have had is back a week now and the noise is now gone.
Sent from my SAMSUNG-SGH-I777 using Tapatalk
Thereaper
Mobile Al.
I have a knocking at the rear of the oil pan when the engine is at idle and hot. It's a loud knock that you can hear inside the car. On a lift at the Dealer it's more noticeable
at the rear of the oil pan.
Thereaper
Mobile Al.
The Tech at the Dealer cut off the a/c belt and the noise went away. Put a new belt on and the noise came back. I'm happy that it's not an internal problem.
Thereaper
Mobile Al.
Yes it was and it sounded like the engine was about to throw a rod. If it happens to you then you will shit just like I did. I didn't want to post about it until I knew what the noise was. It's amazing to me that an a/c belt can make a knocking noise at the rear of the crank.
Mystickeith50
South Jersey
you know whats funny...i had the same issue with my 95 but i thought it was coming from the from of the pan. well its good it worked out for you.
whirledpeaz
tsb 11-7-1
TheReaper,
I remember reading about this some months ago. Found this on F150forum.com:
tsb 11-7-1
5.0l—lower end engine knock at hot idle— built on or before 2/14/2011
Glad its fixed for you.
KJGT
East, TN
My car had the same thing from the day I picked it up, it sounded like main bearing knock and if you put your hand on the valve cover you could feel it. After searching around and talking to someone who had a clue they said right away - AC belt.
I didnt believe it, since I was putting a blower on the car I didnt want to take a chance with an engine issue so before I installed the blower I cut off the AC belt - and the noise was 100% gone. You would have swore it was something serious and not caused by a belt up front. Since the Roush SC uses a spring tensioner on the AC belt the noise never returned either.
SilverChief12
Hello all,
Same problem here. Here is a YouTube video I found. Is this the problem you guys are talkin' about? This is the problem I am having. The Ford guys can't figure it out thus far. This guy has the same problem I have. Ford told him it is "Normal" for the 5.0 to sound like this. I don't think it sounds normal at all. I have no mods, with all the #8 blow-ups I hear, and probally I won't get any. Please see the YT video and comment back. Any help will be great!
http://www.youtube.com/watch?v=c4c8_VNWfT4&feature=related
Thanx,
SilverChief12
Thereaper
Mobile Al.
Hello all,
Thanx,
SilverChief12
That's the a/c belt. The same noise my car had.
Alcarames
Ok, one noise is solved. Can you guys help me with this one. Not my car but the same noise and mine is coming from passenger side. I noticed after second oil change as well, it could've been there before but I didn't notice until about a month after second oil change.
http://youtu.be/3TeFix0OElw
http://youtu.be/SqBJXjOMv4U
SilverChief12
Thanx You for the reply everyone. My 5.0 is sleeping for the winter now......i work that A/C belt thingy out in the spring! maybe they might have more solutions for other problems the 5.0 is having.
Question: where can I find those Ford TSB? on Ford website? or just go on this website? thanx guys for all your help!
