Up for sale is a Spohn Performance Adjustable Rear Upper Control Arm. I bought this off the forums and its in great shape. However I was told it was a 2005-10 arm, the shortest it can go is 8.5" (stock 05-10 length) so it is a 2011-2014 unit.
Asking $80 shipped
Specifications & Features:
Eliminate wheel hop, improve handling, and increase traction.
Stronger, yet lighter than stock.
CNC laser cut and formed 1/4" steel mounting bracket for maximum strength and durability.
3/4" Del-Sphere™ pivot joint eliminates bind.
CNC machined through sleeve and silver zinc plated steel spacers keep the joint perfectly centered inside of the vehicle mounting bracket.
Right hand and left hand threaded silver zinc plated 4140 chrome moly double adjuster threads into 4130 chrome moly TIG welded threaded tube adapter for maximum thread strength.
This is the highest quality, easiest to adjust on-the-car rear upper control arm on the market!
Re-uses factory mounting hardware, no need to drill out your car's mounting bracket holes.
Easy 100% bolt in installation with the use of basic hand tools.
Asking $80 shipped
