SSP's 900+RWHP Turbo Streetcar
SStang
Lol
I am waiting on the shortblock to be done. I should have it here by next weekend and be onto assembling longblock and fabbing pipes
Been busy with my wife's 70 F100 in meantime
Carbed 7,500 rpm custom built 2V in a classic truck. It should be very rowdy
What are specs on this one?
Thanks.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Thanks.
11;1 comp 4.6l with coyote rods stag3 Cnc ported heads with oversized valves and pac springs/titanium retainers custom grind MHS/Bullet cams for carbed combo 240+deg duration @.050 on 108 lobe separation installed @ 106 ICL Victor Jr. Carb intake MSD mod6 box 750 carb
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Sounds like that oughta make about tree fiddy
That motor has made 345rwhp on 9.5:1 comp and much smaller cams and EFI before. It went 12.80's in a 3,800lb convertible with a IRS and 270lb driver
Should be a little quicker in this truck that weighs only 2,900lbs :) plus some added powah now.
We took a 347 stroker out to put the 2V in it. My wife has a attachment to this engine as it was in her 01 vert for several years before.
cbass
m̶o̶u̶t̶h̶s̶e̶x̶
Rochester, NY
Oh man, that looks horrible, it'll never work that way. You should probably cut your losses and sell me that block for $50 so you can recoup some of the cost.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Removed the restriction in main oil feed that was rough cast and small
Cleaned up oil returns too
Zero decked
Watts stamp of approval after doing the sleeves :)
Head studs and boss head gaskets
New cam cap bolts
New oil pump time to pull it apart
Out with the old gears in with the TSS billet gears!
Prelubed the oil pump
Put it all back together
Onto cams chains and phasers
Now to cover it all up
JEWC_Motorsports
S197 Junkie
Texas
Rick, with those types of sleeves is it possible to get more displacement and or run a stroker?
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
You can bore it to a 5.2L
You can get a stroker crank from Livernois also to make a 5.8L
These sleeves are .185" thick at std bore so you can safely go .080-.100" over stock bore and still run a power adder. You could go .120" over stock bore on a n/a combo safely too.
The material in these sleeves is super tough. My machinist said it is a billet quality material that was eating his cutters up when he was boring them. He wore out 4 cutters boring them.
