SSP's 900+RWHP Turbo Streetcar
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Modified oil pump pickup standoff as per arp instructions
Oil return done
ford20
White Plains,NY
Removed the restriction in main oil feed that was rough cast and small
Cleaned up oil returns too
What are you using to clean up the oil returns and what not? I have been thinking of doing the same thing with mine as well but didn't know what to use and how to clean them out.
You can bore it to a 5.2L
You can get a stroker crank from Livernois also to make a 5.8L
These sleeves are .185" thick at std bore so you can safely go .080-.100" over stock bore and still run a power adder. You could go .120" over stock bore on a n/a combo safely too.
The material in these sleeves is super tough. My machinist said it is a billet quality material that was eating his cutters up when he was boring them. He wore out 4 cutters boring them.
Is that with the Darton sleeves?
Oil return done
Why did you have to modify the oil pump pickup? Were you using ARP botls for the oil pan?
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
I used a carbide bit and a die grinder
The galley from the oil filter to the bearings is machined nicely from factory but they left the feed from pump to filter all rough and full of casting flash. I don't know what they were thinking. Priority oil feed restrictions are often overlooked by many builders unfortunately
Yes with Darton sleeves
It has to do with the threads of the stud that stick up past the nut where the oil pump spacer bolts down. It was specifically in the arp main stud instructions with the specs I posted.
ford20
White Plains,NY
Do you think a Dremel would have enough oomph to get the job done?
I will definitely meet up with him at RPR when it's done!!
You have been saying that for the last 9 pages dude lol.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Had a hour after work today so I did this when I got home
Dr side is done enough I can install engine. Just gotta get a few more bends to get pass side done up to a v-band like drivers side and then I can drop in engine. Hopefully my new converter will be here before then so it's not holding me up
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
All that work and money and a stock crank damper??
Yessir it doesn't drive anything other than the alternator and a/c. The engine is zero balanced so there are not many harmonics to worry about.
If it had a blower I would have gone a different route.
Only spinning it to 7,000 rpm too.
slagburn
Harmonics is harmonics, doesn't matter how it's balanced. Not to mention a damper is NHRA required at a certain point. Your money, your car though.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
I don't even have a cage its a grudge/street car. NHRA legal is not a concern for me as it won't ever be a competition vehicle.
Ford did a great job designing the balancer for these motors I haven't seen one of these motors shake mains or have and harmonic issues other than some blower engines that have high loads on the front of the crank.
