Patricio Ugarte
Hey everyone,
I´m posting this looking to get advise, guidance and thoughts on what you think its the problem.
I've been chasing an ongoing issue with my 2006 Mustang GT (4.6L 3V, automatic, Mexico-spec). I'm not the original owner, and it's clear the car didn't get the care it needed. I've done a long list of repairs—some things improved, but the main issue keeps coming back in different forms.
Symptoms before repairs:
-Engine would completely shut off randomly after the pats light flashed and beeped
-B2103 (PATS transceiver) was active randomly
-High CO emissions – 6 ppm (should be ≤ 1 ppm)
-Rough idle, jerks, excessive fuel consumption, misfires (this happened 1 time), power loss (also 1 time)
DTCs seen:
-B2103 – PATS Transceiver circuit fault
-P2196 / P2197 – O2 sensors stuck rich/lean (Bank 1 and 2)
-P0193 – High input from fuel rail pressure sensor
-P1000 – Readiness monitors not complete (this one always disappears after a few driving cycles).
Repairs done
-PCM (not original) reprogramed by Ford dealership. Its important to say that it currently has an XB model, although this car originally requires an FB PCM. At some point the original PCM was replaced for unknown reasons.
-Alternator rebuilt. Voltage was below 13v when running hot; I even noticed tilting lights
-Battery replaced with correct size and properly secured
-Positive cable reinforced, This finally stopped the random full engine shutdowns
-O2 sensors (pre-cat) replaced – from generic AutoZone to Motorcraft
-All 8 spark plugs replaced – they were very likely factory originals and never changed
-Throttle body cleansing
Symptoms after repairs
-Fuel consumption improved after O2 sensor replacement
-Emissions are now under control (CO < 1 ppm)
-But the jerking and hesitation and PATS beeping still happens randomly...even a "check fuel cap" appears sometimes when it jerks.
I have been using a BlueDriver scanner and most recently a OBDLink MX+ with Forscan Lite...But I'm leaning towards the PCM itself being the core issue. The symptoms seem to shift between systems – sensors, fuel pressure, PATS – even after replacing the affected parts. This makes me wonder if the PCM is unstable, incompatible (wrong model code), or simply damaged despite being reprogrammed by Ford.
DTCs seen:
Repairs done
