Stang Drop!!!
ixtlan
Hooper, Utah
Dropped the Stang.
Total drop
Front 1.9
Rear 2.2
And yep I already scraped a Speed Bump.
Gotta avoid those from now on.
Eibach Pro-Kit lowering springs
255 45 17 **Pilot **Sport A/S Plus
Here it be:
BlackOut
NY LI
Looks good... thats the way they should come from the factory
pieperz06
i need to get blown
Corpus Christi,TX
man i like the look but i would not do it because it kills me every time i would scrape it
but it does look nice
ixtlan
Hooper, Utah
It was a sorta high bump.
I will avoid them as much as possible though.
I have some I must go over and I hope they wont scrape.
Kipp07GT
Slug Box
York South Carolina
def. avoid all bumps, im not nearly as low as you but I pulled my x-pipe apart on mine and had to have it rebuilt and rewelded after it got hung on a speed bump.
andyman
what a mess...
tampa
yeah man speed bumps are a BEOTCH with my sportlines! looks good!!!!!!!!!
302
Atlanta GA
Looks good. BTW, have you ever thought of powdercoating those stock wheels? That wouldnt look too bad with the theme you have goin on there.
ixtlan
Hooper, Utah
After letting the springs settle in a week I just got back from having the alignment double checked.
We aligned it initially using this guide:
http://bio.fsu.edu/~heath/mustang/alignment/
We only had the gauge like shown so accuracy was a bit in question.
The older guy (40ish) that put it on the machine (Laser stuff used at Les Schwab) said everything was in spec. All he did was was to tweak the front to bring in perfect because he saw the car belonged to an enthusiast.
If it had been a normal car he would have just called it good.
Needless to say he said excellent work.
So I be a happy camper.
:thumb2:
