2013DIBGT
I Hate Wheelhop
Hello,
Does anyone have the inside skinny or use these Boss Front Control Arms offered by Steeda? Are they any good or are they a cheap knock off?
http://www.steeda.com/11-mustang-front-lower-control-arms-with-bushings-777-4900/
Visually the arms themselves appear to be the same as the real deal 302S replacement units but the Ball and Bushing parts are definitely different between the two. Can one install a HOWE Balljoint into the Steeda Arms?
For me, having a threaded Ball Joint hole in the arms is a requirement. I have Negative ZERO interest in going thru the hassle of burning out the puss filled factory bushing used on the OEM FCA's just to install better Urethane units while still being left with a stretched out Ball joint hole that will eventually end up requiring tack welding so the fucker doesn't fall out.
Surely I could call Steeda and ask them these things but I would rather get an unbiased report from outside parties instead on how these things stack up.
Thanks
Thanks
