Steering column conversion electrical questions
Ryan D
Southern Kentucky
Have searched but haven't found exactly what I'm looking for. Working on build/to-do list for building a drag n drive car for drag week type events and occasional cruising now and then. Will go with 8.50 cert cage but keeping interior except for rear seat delete. Want to go to a race column with quick release for #1 safety and #2 make it a little easier to get in and out around the cage. If I disable PATS, is it just a matter of wiring the right stuff out of the ignition to the switch panel (use a switch for the things that normally get power off of turning the key to the acc position?)
