steering rack spacers
Dallas The-Awsome
are there any steering rack spacers that fit our cars? or longer tie rods? i know i can use washers to make my own but id rather find proffesinaly bult kit type thing if i can
C.Love
I would find a longer outter with a heim in it. IIRC steeda makes some.
C.Love
correction there are quite a few companies that make the longer outer tie rods they call them bump steer kits same difference. your spacer I would probably look at a s13/s14 one measure the threaded area on the inner tie rod connects to the rack. and see if the rack spacers would fit from a 13 or 14. you really do not want to go much thicker than a few millimeters I think on a 240 5 mm is the most you can go.
