Tducomb
I recently have began to delve pretty deeply into my 07 gt, it all began with some phaser noise and well I somehow have ended up having my heads ported and I am installing new camshafts as well. My question is relative to timing, I am aware I need the crankshaft in the 6 o clock position with cylinder 1 at TDC, all I need to worry about with the cams/phasers is that the intake valves for cylinder 1 are fully closed as they would be for the power stroke? I’m in a bit over my head with the process so if anyone has any suggestions as far as to making sure the cams are in the right position relative to the position of the crank, please let me know!
