Are upgraded valve springs necessary as well if using stock heads and cams at 600-650rwhp under 7k rpm?
So, stock valve springs and retainers are ok running 17psi under 7k rpm?
I don't think there is much to it. The machine shop does the important stuff like balance and machine. You can be real anal about verifying everything or trust the machine shops numbers. I have a machine shop I trust so that makes it alot easier. I also had them fit the rings. I used Harbor Freight torque wrenches. Verified them against my neighbors certified wrench.
After everything is prepped it's just putting parts together and checking a few things like endplay and torque to turn the crank.
Here's the Ford manual if you haven't seen it before. http://iihs.net/fsm/?dir=159&viewfile=Engine.pdf
If I was going after a mega hp motor I'd have a reputable race shop build the motor. But I'm not doing that and I trust my ability to follow written instructions.
Good advise! Look at Bruce and myself, we have very different motors in our cars. His is more to factory spec and mine built more to the loose side like a race engine would be built. His most likely has about .014 rod clearance while mine has double that to get the oil out faster.
That's a pretty good guess. Just looked at the build sheet and they are from .014"-.016". These rods were sold to me as used Eagle but I think they are just no name China h beams with arp2000 bolts. Had the machine shop check them out before I used them. I didn't have to do anything to adjust the side rod clearance.
Do you want the oil out faster for better cooling?
Building your own engine is half the fun. I'll be assembling my shortblock once i get everything back from the machine shop.
I know a little something about something. LOL
As for the cooling affect, my motors like I said was built buy an old school builder. He explained it all to me a long time ago but this is what I remember. The less time a fluid spends in a heated environment, the less heat is built into the fluid. Just like adding a larger coolant system with more flow. Sure over time it will get just as heated as any other but in the short run it will flow more . Made sense to me for the track. If you have a larger capacity and more flow, the longer time it will take to heat it beyond its limits.
And the real fun begins the first time you watch some else make a dyno pull on the motor you built yourself! Hell I thought I was going to throw up on my first one.
Hahaha you should have seen me at the dyno after I installed my cams. I just knew shit was about to break. I can't imagine how I'd feel before dynoing a motor I built that was about to see 800 horsepower
Oh , I have kids, we can make mad throw up vids if necessary!I would volunteer to show up. But we'd need a third to record me throwing up in reaction to you throwing up. Lol
