Norm Peterson
corner barstool sitter
Moving the contact patch further outward will affect the alignment that the car actually sees when you're driving it (your toe changes slightly from the static setting due to tire rolling drag and suspension bushing compliances). So you might want to consider a small change in your toe setting.So what is the worse thing that would happen if I put these 18's on my 11? More rock chips since the offset on the wheel is not for the 11+?
That size will work well on either 9" or 9.5" wide wheels.The tires you are advertising for the 18's for the 2005-12 are the 255/45/18 Nitto Nt555
Norm
