Napoleon85
A little bit of background and my current setup:
I've been running the below setup for a while now, and it's worked very well except for one issue. I could not get the rear end to behave properly when under lateral loads (hard cornering).
I knew it all along, but I finally came to terms with the fact that the only way to fix this was to eliminate some of the poly bushings that were binding up. Everyone told me not to do it, that rod ends only belong on race cars and they will be way too loud on the street. I'm here to tell you this is just not true!
I installed my UCA with no additional lubrication, and got a little bit of noise out of it, but you would only hear it with the windows up and the radio off ... so never. Here's a short video I made, babying the exhaust so that it wouldn't drown out the noise.
Going into the LCA install, I prepared for this amount of noise to triple, but I spoke with Sharad at UPR and he recommended using a dry lube with PTFE/Teflon in it as a lubricant. This will keep the rod ends lubricated, but will not attract dirt, debris, or moisture. I found this at Autozone for about $6:
http://www.liquidwrench.com/products/#!/5
I completely soaked all the rod ends in this stuff, and afterwards I have virtually zero noise from them. I purposely made them articulate with the windows up and the stereo off and could not hear a thing. I think I heard the slightest noise when getting out of the car, but I can't even be sure it was one of the control arms. I'll make a follow-up video soon and post it here.
Even better news was the dramatic difference when putting the car under high lateral loads. The binding and snap oversteer that I had learned to "drive around" were completely gone, and the entire suspension was articulating smoothly.
Bottom line - if you plan on pushing the car hard through corners and dont mind a bit more NVH and having to occasionally lubricate the rod ends, definitely choose them over all poly bushings. Here are links to the exact arms I'm running now if anyone is interested.
UCA/Mount
http://www.uprproducts.com/mustang-...ouble-adjustable-upper-3rd-link-mount-11.html
LCAs
http://www.uprproducts.com/mustang-chrome-moly-double-adjustable-lower-control-arms-street-05.html
- Koni Yellow/Sport Struts/Shocks
- FRPP/GT500 Strut Mounts
- Eibach Pro-Kit Springs
- BMR Tubular K-Member
- BMR A-arm Brace
- Eibach Adjustable (F&R) Swaybars
- UPR Pro Series Double Adjustable UCA & Mount
- UPR Billet LCAs
- UPR Pro Street Double Adjustable Panhard Bar
- BMR LCA Relocation Brackets
UCA/Mount
LCAs
