tensioner clip tool
fastregalwe2
Need more powa!
Virginia Beach, VA
Is there any other way to install the tensioners without the clip tool? If not where can I get it. Went to the Ford dealer and the rude jerk offs said they dont have Ford tools.
Yes it can be done. If I was to do it over again I'd just get new tensioners (they come with the clip).
Start a bolt and force the tensioner into position enough to get the other bolt started, you can figure it out from there.
tmcolegr
It's All About the Build
Central, FL
SD mentioned something about using a paper clip. Perhaps you could PM him......
fastregalwe2
Need more powa!
Virginia Beach, VA
Thats what I ended up doing, it was a PITA but I got them on
thanks
US-1
Banned
The ShadowLands
If you're going to buy new tensioners then you need to buy the cast iron versions from the older 2V engines.
The clip to hold the plunger down on the plastic tensioners is somewhere around $7.
tmcolegr
Central, FL
I sure wish I would have known that before purchasing a brand new pair of the 3V tensioners for my build
94tbird
4R70W FTMFW
so one failure in 5 or 6 years? you can compress them with your fingers when oil pressure is lost
Redfire
I had a tensioner arm fail due to the basic design of the tensioner. The plastic tensioners will allow the chains to "whip" when pedaling the car putting strain on the arm. The steel tensioners with the ratchet will keep tension on the chains and will limit the amount of whipping action. When I put my engine back together recently I used the steel tensioners to prevent this problem.
94tbird
4R70W FTMFW
got a part number on them? Since ive got the engine out i might as well
tmcolegr
Central, FL
I assume the tensioners were the only items upgraded and you retained the remainder of the 3V timing components?
tmcolegr
Central, FL
here's a picture of a steel bodied tensioner
picture.php
