one eyed willy
Pizzle fo shizzle
i have a 07 also,just swapped mine to a 160 when i did the cmdp. now im wondering if i should swap it back??
well im in flrida,it usually takes 4-5 minutes to reach 198 or so, i will be turbo with in the month and dyno tuned shortly after.
Wow, what a PITA - glad I have an 05 & 06.
I know this thread is way old, but I didn't see any other threads contrary to this one, about having to remove the intake to swap the t stat on an 07+. Its easily done by removing the throttle body.
My car's temp spiked yesterday for no apparent reason, up to 220, for about a min, then back down to 195. Figured I'd change the t stat first. I was able to get to the back bolt no problem with a small 8mm wrench, and since the housing is notched, you dont take the bolt all the way out. After removing the throttle body. The whole job took maybe 30-40 min.
This may be old news, but it was new to me since I just got this car.
